TX Super clean 600whp EG Hatch
Old 04-20-2018, 03:10 PM
miahjera04's Avatar
Default Super clean 600whp EG Hatch
Building a new house, so toys gotta go.
located in sour lake,tx
4093502520
price: $13k or trade value of $15k
BLOCK
b18b1
CP pistons upgraded pins
Eagle rods
ARP hardware
Polished B1 crank
C5 oil pump
Toda Racing billet pump gears
ATP harmonic balancer
C5 water pump
Gates racing timing belt
Eagle blockguard
Eagle lsv plate kit
Moroso pan
Oil pan stud kit
Speed factory oil pan gasket
Billet torque mounts
ARP crank bolt
Amsoil
HEAD
b18c5 head
Port matched
Supertech valves
Supertech springs/guides/seats
S2 throttle body
ARP exhaust studs
Thermal intake manifold gasket
Edlebrock manifold
S2 cams
AEM cam gears
S2 cam caps
S2 vtec solenoid cap
ARP head studs
Oem honda head gasket
Powdercoated valve cover w/10an bugs
Downstar cam gear bolts
Custom plug cover
NGK plug wires
Modified dizzy w/HVC external coil
m&w pro10
T1 pro10 harness
S2 valve cover hardware
Samco silicone rad hoses
FUEL SYSTEM
full blown billet dual hanger
Twin walbro 450s
2nd pump on hobb switch 4psi
10an feed
6an return
Full blown regulator
Golden eagle rail (powdercoated)
FID 2200s
ID F750 billet filter
FP gauge on rail
TRANSMISSION
synchrotech built
Quaife LSD
LS gearing
Carbon pro series synchros
Torco rtf
Painted wrinkle black
Aftermarket shift linkage
Billet linkage mounts
K tuned shifter powdercoated
S2 weighted ****
Insane shaft 1000hp axles
TURBO KIT
Custom manifold (dei wrapped)
Pte6262 2nd gen ported S cover
Powdercoated cold side
Custom backdoor FMIC (powdercoated)
Custom cold side piping (powdercoated)
Tial wastegate
Tial bov
3 port boost solenoid
Braided ss boost lines
Custom 304 stainless 3\\\\\\\\\\\\\\\" exhaust
(2) 304ss vibrant resonators
Vibrant t clamps
SUSPENSION/CHASSIS
BC racing coilovers
Poly bushings throughout entire car
BWR rear subframe brace
BWR rear lcas
S2 ucas
Ecm spherical tie rods
New rack & pinion(manual)
Powdercoated suspension parts
BWR Trac bar
S2 strut braces
Billet motor/trans mounts
BWR rear camber kit
WHEELS/TIRES/BRAKES
15X10 6ul on 245/55 m&h
17X8 6ul on hankooks
Stoptech rotors
Stoptech braided brake lines
Hawk pads
Brake line tuck
Powdercoated MC
Powdercoated calipers
ARP wheel studs
Steel lug nuts
ENGINE BAY
Custom radiator(polished)
Aluminum fan shroud
Spal fan
Moroso twin catch cans (powdercoated)
Billet rad overflow (powdercoated)
Powdercoated rad plate
BWR rad stay
Downstar spike hardware (powdercoated)
Wire tuck
Brake tuck
CF NRG hood struts
PWjdm CF dizzy cover
s2 rad cap
Golden eagle billet oil cap
EXTERIOR
Custom paint (few years old)
Fresh painted exospeed 3 piece front
Pci side skirts
Vis CF hood
Seibon CF hatch
Seibon CF wing
CF wrapped roof
LED headlights
Smoked tailights
Black headlights/corners
Aerocatch hood latches
CF mirrors
CF fuel door
Billet rear diffuser (powdercoated)
INTERIOR
very clean oem look
10 pt chromoly cage
Takata driver seat w/takata 6pt harness
NRG pass seat w/simpson 5pt harness
CF wrapped dash bezel
SiR cluster w/leds
AEM boost,afr,oil pressure gauges
Custom switch panel w/s2k list to start
Eg6 floor mats
Rear seat delete kit
CF rear cargo cover
Optima yellow top mounted in spare tire location
NRG quick release setup
Momo steering wheel
May be forgetting some stuff too...
miahjera04 is offline
Old 04-21-2018, 09:02 PM
HATCHBACK GORILLA!'s Avatar
Default Re: Super clean 600whp EG Hatch
Bump for a seller i have personally spoken to and he is a great guy. The new owner will be more than happy with this amazing car!
HATCHBACK GORILLA! is offline
Old 04-21-2018, 09:31 PM
GIZZ - EXV's Avatar
You did a ton of modding, there are the obvious mods, and then everything else is also touched. Well done.
GIZZ - EXV is offline
Old 04-22-2018, 04:33 AM
miahjera04's Avatar
Old 04-22-2018, 04:34 AM
miahjera04's Avatar
yes, this car is show car quality and fast. Best of both worlds
Old 04-23-2018, 07:37 PM
heat.'s Avatar
amazing quality build, hopefully this finds the right owner
heat. is offline
Old 04-24-2018, 05:41 PM
miahjera04's Avatar
thanks. Got 2 potential buyers currently.
Old 05-15-2018, 09:48 PM
Woojen's Avatar
You have PM could bid 15k$ Cash
Woojen is offline
Old 05-16-2018, 07:33 AM
Dublocivic's Avatar
Super nice car for a super good deal! GLWS!
Dublocivic is offline
Old 05-26-2018, 09:37 PM
B and B's Avatar
Where do the VC vent lines go? Can't see the the catchcan for those?
Car is a dream.
B and B is offline
Old 06-11-2018, 07:32 AM
DallasOM33's Avatar
Did this sell? I'm in Texas
DallasOM33 is offline
Old 06-24-2018, 04:38 PM
Ckamal's Avatar
How much does it cost for one ride?
Ckamal is offline
miahjera04
12-24-2017 10:35 AM
x still jaded x
09-07-2010 05:19 PM
x still jaded x
09-07-2010 04:05 PM
gezzuzz
09-13-2008 03:46 PM
moyo_rican
04-26-2007 08:56 AM
Quick Reply: TX Super clean 600whp EG Hatch
