D16Y8 question
Old 01-18-2018, 01:46 PM
Bob112's Avatar
Default D16Y8 question
Hello everyone. I recently swapped an engine into a 97 EX. The guy said it was a D16Y8 and the block is stamped with it. There is a couple difference from the one that I took out (D16Y8) and the new one. First there is no dipstick, no location for the crank position sensor, and the oil pan is different. I need a new oil pan seal but not sure what to get. Any ideas on where to start? What type of engine?
Old 01-18-2018, 02:58 PM
Fish Twig
tony_2018's Avatar
Default Re: D16Y8 question
Don't know.
Old 01-18-2018, 03:21 PM
mk378's Avatar
I think the alloy oil pan uses only Hondabond or other sealant, there isn't a gasket. The steel pan is conventional with a cork gasket. Either type of pan can bolt onto the same block.
The crank sensor may bolt to the oil pump, which looks like it is part of the block at first glance, but is removable.
Old 01-19-2018, 03:33 AM
Bob112's Avatar
The pan is steel but the gasket I had does not line up and is to big.
nomadic
05-17-2010 05:40 AM
coehonda
05-04-2010 01:29 AM
88EF
04-04-2003 06:38 PM
Quick Reply: D16Y8 question
