94 Del Sol, Replaced ECM, still cutting off while driving
Hi All,
My 94 Del Sol, like many I've seen posted here, is cutting out while driving. Sometimes it starts right back up, sometimes you have to wait. Replaced the distributor cap, fuel filter, and ECM (PN 37820-P06-A52, which I bought with a 60-day guarantee on eBay). Still cutting out. Before I replace the ignition module/coil, does anyone know if the ECM requires some reset procedure/sequence to synch in some way? Any other suggestions are appreciated! So frustrating!
Re: 94 Del Sol, Replaced ECM, still cutting off while driving
I've never had this issue with a Honda, but had an issue with my 2005 Pathfinder cutting off while driving. The issue happened once in a blue moon, then started once a week, then finally multiple times a day to where it was scary to drive it anymore. After replacing my ECU, and cam sensors it was finally fixed by replacing the crank sensor.
phrewil
11-03-2014 05:16 AM
