Post mount question!
Car: Honda Civic 1998 LX Motor:JDM SIR b16a obd0
I have a JDM B16a obd0 and the driver side POST MOUNT is different so my aftermarket engine mounts wont fit correctly (Driver Side ONLY), Since the aftermarket engine mounts are made for B Series Engines.
My question is can use any 94+ Integra Post Mount or do i need a EM1/B16a2/SI,
Ek Chassis 98, Aftermarket Ek to B series but I know you can use stock mounts for any B Series if its a 2 bolt driver side post
A pic of your driver's side aftermarket engine mount and the model chassis/year would be very helpful (unless we can assume that the chassis is the white EK in your Avatar).
The standard engine bracket (post mount as you put it) on an OBD-0 JDM B16A would be like that found in a US DA Integra (90-93) and typically works with EF B16A type aftermarket mounts.
If a pic is a problem, here is the long answer:
If your aftermarket driver's side mount has two holes in it, you will need to get a '99-00 Civic Si (EM1) engine bracket.
If it has three holes in it, you will need a '94-01 Integra (DC) engine bracket.
No Integra had a 2 bolt post mount, none of them. The only B-series equipped cars that came with the 2 bolt post mount were: '94 - '97 Del Sol VTEC, '99 - '00 Civic Si, '97 - '01 CR-V (this one is a little longer than the rest and lets the engine sit a little lower on the driver's side) JDM Orthia (I think it's got the same mount as the CR-V) and '92 - '00 JDM civic with B-series.
do you have the correct T bracket as the EG/Teg mount doesnt work in an EK chassi
and will put the engine in the wrong place for the engine post mount
what car did the engine come from ??
I got the right bracket Si/Em1 T bracket onto my ek chassis, the motor is a stock JDM b16a
a crooked engine make sure u have the right t bracket ls is different from the gsr and b16 if im not mistaken that happened to me with my b16a2 on 1999 lx.. and used same mounts just used b16a2 driver block mount.
Assuming we are comparing "manual" T-brackets... '94-01 Integra LS/GSR are the same, and you would use this type for ALL "B" Series DOHC swaps in '92-95 Civics, '93-95 Del Sols ('96-97 if it has the EG type sub-frame/steering rack), and '96-00 Civics using EG/DC2 rear sub-frame/steering racks. The B16A2 rear "T" bracket is different (shorter from front to back) and should be used in standard chassis '96-00 Civics with the stock/original rear sub-frame/steering rack.
Cian Mcloughlin
Oct 31, 2013 06:07 PM
NoL1MiT_DC2
May 6, 2010 01:18 PM
