NEed wiring schematic or Diagram
Some idiot thought it would be cool to break into my car and steal my radio last week and to do it they cut the master harnes. I need to rewire in a harness but I can't find anything that tells me what wires do what. I am in the process of moving so my Haynes manual is in a box somewhere. Can someone get me the schematic or type in what colored wire does what? I have a 1998 Honda Accord Sedan EX. Oh, and now my interior dash lights won't work so I am guessing that there is a circuire that was cut when the harness was cut. Any help would be appreciated.
Thanks,
AGT
Thanks,
AGT
Re: NEed wiring schematic or Diagram (AustinGT)
just find out the hard way... take out the fuse.. and take a small battery and start puting wires minus and plus till u heard noise comin off ur speakers when u get all 4 u will be left with only a few wires left for power wont be hard to figure them out after u found all the speaker wires
Re: Need wiring schematic or Diagram
I know which ones are the speaker wires. I just don't want to blow up my stereo by having the 12v power supply and 12v battery supply switched. Here are the wiring colors that I have found. I really only need help with a few:
Black(thick) - GROUND
White with red stripe
White with green stripe
Red with silver dots
Blue with green stripe - LEFT FRONT SPEAKER
Red with black stripe
Blue with silver dots
Black with silver dots (thin)
Grey with white stripe - LEFT REAR SPEAKER
Brown with white stripe - RIGHT REAR SPEAKER
Blue with yellow stripe - LEFT REAR SPEAKER
Red with yellow stripe - RIGHT REAR SPEAKER
Grey with black stripe - LEFT FRONT SPEAKER
Red with green stripe - RIGHT FRONT SPEAKER
Brown with black stripe - RIGHT FRONT SPEAKER
If someone knows or has a haynes or Chilton Manual, can you look it up for me and see if it says anything on the ones that I am missing?
Re: Need wiring schematic or Diagram (AustinGT)
White with red stripe - switched ignition
White with green stripe - battery input
Red with silver dots - dim control (-)
Red with black stripe - dim control (+)
Blue with silver dots - ? not listed...
Black with silver dots (thin) - antenna input
Blue with green stripe - LEFT FRONT SPEAKER (+)
Grey with black stripe - LEFT FRONT SPEAKER (-)
Red with green stripe - RIGHT FRONT SPEAKER (+)
Brown with black stripe - RIGHT FRONT SPEAKER (-)
Blue with yellow stripe - LEFT REAR SPEAKER (+)
Grey with white stripe - LEFT REAR SPEAKER (-)
Red with yellow stripe - RIGHT REAR SPEAKER (+)
Brown with white stripe - RIGHT REAR SPEAKER (-)
Re: Need wiring schematic or Diagram (philadd)
Hey thanks for that info. Can I ask where you got it from and if it is possible to scan in an image of the diagram if you still have it?
crxaddikt
07-08-2017 07:56 PM
