Hose help.........
Old Mar 31, 2017 | 02:35 AM
Baby99EX's Avatar
Default Hose help.........
Hey does this middle grren hose, i think its fuel, does it connect to the little nipple on the back of the intake manifold?? Please and thanks......
Old Mar 31, 2017 | 05:22 AM
mk378's Avatar
Default Re: Hose help.........
I think it's the vapor line from the gas tank. It should go to the EVAP canister. The green plastic tube is of course not stock.
Either that or the fuel return line from the fuel pressure regulator. In that case, it needs to be proper rubber hose with clamps. A fuel leak will ruin your day.
The little nipple on the back of the intake is for the cruise control actuator, if equipped.
Old Mar 31, 2017 | 05:25 AM
BryanM.'s Avatar
Resident Gearhead
Goes to the EVAP charcoal canister I believe.
vapor line > EVAP > Purge Control solenoid > intake plenum
someone correct me if I'm wrong
Old Mar 31, 2017 | 09:15 AM
710times's Avatar
sounds right to me. I had a evap issue on my Saturn and I learned the evap system quick
Old Mar 31, 2017 | 11:25 PM
Baby99EX's Avatar
doeshis look right?? connected the gas tank line to the EVAP canister.........
...........the IM lines here are not set up the exact same way, but it should still be correct right??
Old Apr 1, 2017 | 02:58 AM
petr0lb0mb's Avatar
Holy barnacles, Batman! That rust! Remind me never to leave Cali. Here's my 99 EX.
Coincidentally, I just deleted my evap, so my picture is of no help to you other than to let you know what your car looked like before 18 years of Winters took its toll.
Old Apr 1, 2017 | 03:06 AM
Baby99EX's Avatar
immaculate bruh, im jealous, but why no EVAP? haha dont u need it??
Old Apr 1, 2017 | 03:41 AM
mk378's Avatar
Baby99, that's wrong. The port on the firewall side of the canister (to two way valve) is the one that goes to the back of the car. The two-way valve is near the tank. It appears that is already hooked up with the larger hose. The pipe that had the green tube on it in your first picture must thus be the fuel return. If you look at Petr0l's picture, it has a rubber hose on it that would go the fuel pressure regulator if the engine weren't removed.
Old Apr 1, 2017 | 05:15 AM
Baby99EX's Avatar
ok, so that hoes does NOT go to the EVAP can........what does the can connect to, and u meant the drivers side? hose going to the FPR right??
Old Apr 1, 2017 | 03:04 PM
Baby99EX's Avatar
bump
Old Apr 1, 2017 | 09:02 PM
petr0lb0mb's Avatar
Hopefully this helps.
Old Apr 2, 2017 | 01:33 AM
Baby99EX's Avatar
I cannot find that little black box, the sensor....idk what to think but i dont remember taking one off, is there somewhere else it could go??
heres the line from the bottom of the FPR........
Old Apr 2, 2017 | 01:56 AM
Baby99EX's Avatar
thanks for the help man.......but for real, i didnt see that evap or any evap for that matter when i took it out, so what else does it go to???
Old Apr 2, 2017 | 03:19 AM
Baby99EX's Avatar
It connects to the IACV.......
Old Apr 2, 2017 | 06:45 AM
mk378's Avatar
The purge valve, the squareish plastic part featured in the picture in post 11, bolts to the two tapped holes in the top of the fuel rail. It gets vacuum from the port on the manifold that you have incorrectly connected to the bottom of the fuel pressure regulator.
The port on the bottom of the fuel pressure regulator goes to the line on the firewall that you asked about in the first post.
Then the little coolant lines that go to the IACV are another issue altogether. If you look at the drawings on a dealer parts site, they show all the hoses and where they connect to.
Do not use that hardware store braided vinyl hose anywhere under the hood. It can't stand high temperatures.
Old Apr 2, 2017 | 08:28 AM
Baby99EX's Avatar
ok but what do i do if i dont have the purge valve, buy one??
Old Apr 2, 2017 | 09:24 AM
Baby99EX's Avatar
im sorry but those 2 bolts hold the throttle cable....
Old Apr 2, 2017 | 10:28 AM
mk378's Avatar
The purge valve bolts to the fuel rail. The bolts for the throttle cable bracket are in the manifold. If you don't know what the parts are called it is going to be hard to get any help.
Old Apr 2, 2017 | 11:30 AM
Baby99EX's Avatar
no wonder then, this is my first d16y8 rebuild......so do i have to order a purge valve or what??.
Old Apr 2, 2017 | 11:42 AM
mk378's Avatar
Junkyard. The same valve was likely used on a lot of different models. You may want to wait until you have the car more put together so you can see if any other parts are needed.
Old Apr 2, 2017 | 02:17 PM
Baby99EX's Avatar
iI fund it.....u guys shold have told me it was on the uofuel injector plugs pece of plastic haha....but its there......now what do i hook it to? The EVAP, and the other end to what exactly, somewhere on the manifold? Thanks a lot.........but what do the fuel nipples there hook to? please......thanks......
Baby99EX
Apr 7, 2017 12:36 AM
hondaaccordf23
Jun 29, 2012 06:48 AM
davidt1
Apr 1, 2012 10:27 AM
jachrist
Oct 7, 2009 01:46 PM
the0ne
Dec 10, 2004 06:20 PM
