Honda N600 mid-engine CBR1000RR street / track build @ Blackbird Fabworx
Old Jan 14, 2017 | 10:01 AM
  #51
smilindave's Avatar
Default Re: Honda N600 mid-engine CBR1000RR street / track build @ Blackbird Fabworx
Ok, so what's up? No updates or anything?
Regards
Dave
Old Jan 16, 2017 | 07:57 PM
  #52
BlackbirdFabwrx's Avatar
Not much to add to the thread over the last couple of weeks..
Been out of the shop for the holidays, then came to a mountain of orders that took some days to fulfill and had a couple of small projects to get in and out.
I'll update soon
Old Jan 17, 2017 | 10:53 AM
  #53
tony_2018's Avatar
Fish Twig
All gravy, everybody needs that time in their lives to act like a bear and hibernate. Looking forward to this in 2017.
Old Jan 26, 2017 | 10:56 AM
  #54
While we're waiting on a few parts to arrive, the owner of the car and I had a couple beers at the shop last night and started playing with welding rods and a roll of painter's tape.
The result was a visual mock up of the rear fender flares I have in mind for this car -
Old Jan 27, 2017 | 06:56 PM
  #55
Bently_Coop's Avatar
Steve at Heart
Old Feb 14, 2017 | 04:17 PM
  #56
MikeTee's Avatar
Very nice work and interesting build. That machine will be a blast to drive once ready, I bet! A couple thing came into my mind once I started digging around more about the QBA11R.
Quaife offers two transfer ratio options: 1.00 and 1.25 and three Reduction ratio options: 2.430, 3.025, and 3.767. Which ones did you end up choosing for your build? Thinking of building something similar in the near future and trying to figure what I'd need to haul together before starting to put things together. Mine would be a street car only though (at least I'm thinking so since I'm not a racer... yet?).
Also, are you planning on using Ford Escort/Fiesta CV joints and drive shafts to connect to the QBA11R or did you get the quaife flanges too?
I have a turboed Hayabusa engine sitting in the garage, waiting to be used for something fun. Engine is fully built and dynoed at 450hp. Any idea what Quaife rates the QBA11R for? I wonder if it will handle 450hp engine power and 219ft lb torque?
Old Feb 16, 2017 | 02:46 PM
  #57
94 Civic Si's Avatar
Premium Member
Loved
Community Favorite
Originally Posted by BlackbirdFabwrx
Is there anyone reading this?
Make a sound
Ha ha, just saw this. Yes, reading AND enjoying this quite a bit.
It seems like a quiet crowd here on HT...
Old Feb 20, 2017 | 04:26 PM
  #58
marcair's Avatar
Thoughtful professional work. 10 years ago I installed a hayabusa in a honda beat using the q uaife diff with the same ragemotorsport drive assy. After 30k miles I can offer some comments about weak points if you're interested. Main issue is heat and too small oil capacity. Rage sells a mechanical pump that installs at fwd breathe. I chose to add separate coolers for both oil systems with out the pump. 100% increase in oil capasity and significantly reduce temperatures. Few years ago combination heat and design issue caused the 3inch blowout in the casing shown. Rage should have corrected the stress riser by now with a simple chamfer of the machine edges. Sorry for the upside down pics.
last summer rebuilt hayabusa to 1550cc with out any issues with the rage/q uaife assy. Also you may find the need to safety wire the bolts that attach the halves of the rage unit do to harmonic exposure.
Old Apr 2, 2017 | 03:31 PM
  #59
Been back at it with this project and got a bunch of work in the nose done, so we were able to put the nose back on.
Before it went on I snapped this funny pic of the splitter from one of our customer's track car in front of the car, Frank was super excited about the possibilities!
Got the Tilton pedals mounted and the ATL fuel cell -
Then we fabricated a pair of internal gussets where the structure got stitched back together and clamped the nose.
Using the fenders we realigned the nose and tacked it back in place -
Once tacked, we bolted the hood to verify that everything lines up well.
Was as good as stock so a few more tacks and we're good to weld it Monday morning.
You can also how far we stretched the wheel base -
We need to fab new fenders anyway so it doesn't really make a difference.. :wink:
Old Apr 5, 2017 | 10:21 AM
  #60
More progress shots.
The nose is getting full now that we stuck a radiator in it too (Mishimoto aluminum rad for Civic).
We tilted it forward at the top with the anticipation of adding extraction ducting in the future.
Also note both rad and fuel cell are moved to the passenger side to offset the driver's weight -
View from the inside before the new firewall is going in -
Moving the wheels so far outboard allowed us to cut the wheel wells quite a bit and creates a far more spacious pedal box with the pedals moved left to set them much closer to being centered with the driver.
The way the car was set up from the factory had the pedals way off center to the right.
We also cut the front fenders to clear the MUCH bigger tires all the way lock to lock at full compression.
Car looks angry!
Old Apr 5, 2017 | 10:24 AM
  #61
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
That thing looks like it is gonna do some mad skids when it's done!
Old Apr 6, 2017 | 08:02 AM
  #62
garm's Avatar
I'll jump in, finally. I'm the owner.
Last night we progressed with the mockup for fenders and aero. Moti did his wizardry with wire and tape. There was beer. Good times, and we can see the shape evolving as we continue with the mechanical progress.
Old Apr 6, 2017 | 08:04 AM
  #63
Caoboy's Avatar
-Intl Steve Krew
Loved
I didn't know skeletons could type!
Old Apr 6, 2017 | 08:07 AM
  #64
garm's Avatar
clackety-clack. They can drive too!
Old Apr 6, 2017 | 05:53 PM
  #65
We got curious today and put the car on the scales.
See if you can guess how much the car weighs as it sits currently -
w/ complete drivetrain minus axles, dry radiator and fuel cell, full cage, no glass, most exterior sheet metal minus cut fenders and doors, wheels, tires, pedals, brake rotors w/o calipers, full suspension.
3, 2, 1, GO!
Old Apr 6, 2017 | 06:39 PM
  #66
grumpys93's Avatar
1600 lbs
Old Apr 7, 2017 | 06:45 AM
  #67
Not even close, haha!
We weighed in at 989 Lbs.
Weight dist. is a great 42.5% Fr / 57.5% Rr and side to side is nearly even.
Our original projections for the car were 1250 total weight w/o driver and a weight dist of 40-45% Fr / 60-55% Rr, looks like we're right on target!
Old Apr 8, 2017 | 03:16 PM
  #68
Caoboy's Avatar
-Intl Steve Krew
Loved
Yeah but how will it fare in a crash doe?
That thing is super light!
Old Apr 10, 2017 | 06:20 PM
  #69
Much better than the original!
Old Apr 11, 2017 | 05:50 PM
  #70
Caoboy's Avatar
-Intl Steve Krew
Loved
Old Apr 12, 2017 | 04:13 PM
  #71
e30bimmer89's Avatar
I LOVE this thing!!!!! Can't wait to see it finished up and running laps and the looks on peoples faces. Gonna be awesome!
Old Feb 15, 2018 | 10:25 PM
  #72
Been a while since our last update...
Working currently on the exhaust, starting with a nice equal length header -
Old Feb 16, 2018 | 03:59 AM
  #73
Caoboy's Avatar
-Intl Steve Krew
Loved
It's still alive! Good to see!
Old Mar 5, 2018 | 10:37 PM
  #74
Finished the cooling system plumbing and exhaust system.
Coolant pipes are all hard lines, bend to shape and bead rolled, we're just waiting for the specific rubber couplers we bought for the car -
Exhaust sys was very tricky because of the tight space constraints.
We wanted to make sure we build the header with equal length primaries and secondaries which made it even trickier, but the end it all worked out with some creative use of the space -
Old Mar 6, 2018 | 10:32 AM
  #75
DumpdEJ6's Avatar
I like the tuna here
Woo! This is fantastic! Any idea of power loss by powering two heavier wheels/tires, or are you planning on it being offset through larger exhaust/better intake/etc?
