hasport shift linkage problem
Old Jan 11, 2008 | 06:32 PM
  #26
I CRX I's Avatar
Default Re: (4163175587)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4163175587 &raquo;</TD></TR><TR><TD CLASS="quote">Do a write up on this? It would be a perfect FAQ. Good job.</TD></TR></TABLE>will do my friend, i just wrote it here because i was part of the discussion.
Old Jan 11, 2008 | 06:37 PM
  #27
GSX 4G63T's Avatar
Notify CRX Toad to be credited.
Old Jan 12, 2008 | 06:15 AM
  #28
Boosted Chemist's Avatar
Default Re: hasport shift linkage problem (keithg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by keithg &raquo;</TD></TR><TR><TD CLASS="quote">The warranty repair I mentioned above includes drilling out the the rivet/bolt and replacing the worn bushings with delrin bushings and replacing the rivet with a new one, if you send it to us, or with a bolt and locknut if we send you the repair/bushing kit. If you have a hasport EF shift linkage with this problem it's free for the asking. I will post the instructions on this thread when I get back to work on monday so you can see what I'm talking about. Replacing the rivet with a bolt and nut and cranking it down isn't a good solution to the problem as the u-joint needs to be able to swivel to work properly.
Keith Gillespie
Hasport Performance</TD></TR></TABLE>
Pm sent
Old Jan 12, 2008 | 07:15 AM
  #29
88crxvtec's Avatar
Default Re: hasport shift linkage problem (Boosted Chemist)
I'm planning on using the hasport fix soon, I'll post a writeup with some pics when I do.
Old Nov 23, 2011 | 05:57 PM
  #30
First.EG's Avatar
i know this is an old tread but i did exactly what I CRX I did and it worked perfect for me on my eg. Thanks this was about the only tread i found that was helpful.
Old Jan 21, 2017 | 12:02 PM
  #31
lolv8s's Avatar
10 Year Member
Can't get the shifter lever to mount up right.... the pics speak for me. Ordered the missing parts I needed. I'm probably doing something wrong. Is the space I have acceptable? I ordered some o rings too. Should I just put the o rings and call it over?
JDMfan77
Jun 24, 2010 07:06 PM
jvaughn
26
Mar 16, 2008 06:25 PM
92hatchboi
Oct 22, 2007 06:13 PM
posterchild
Apr 2, 2004 04:26 PM
Hate
Nov 7, 2003 04:49 AM
