99 Civic HX CVT Stock: First no crank, and now cranks but won't start
Old Nov 12, 2016 | 04:16 PM
  #251
chrysler kid's Avatar
Default Re: 99 Civic HX CVT Stock: First no crank, and now cranks but won't start
Couldn't find much info, but is your vacuum routed to this control valve for the egr?
find much info on the vacuum diagram for the egr valve on the CVT hx
Old Nov 12, 2016 | 04:28 PM
  #252
36190-P2J-003 - Genuine Honda Valve Assy., Frequency Solenoid
Maybe?
Old Nov 12, 2016 | 05:42 PM
  #253
madnad's Avatar
Originally Posted by chrysler kid
This seems like it.
Old Nov 12, 2016 | 06:11 PM
  #254
Is it hooked up correctly?
I am unsure of its function, if it is to aid in the egr opening, or to prevent it to open. It looks like one side of it is atmospheric to relieve pressure from the intake to the egr to prevent vacuum to the egr valve
Old Nov 12, 2016 | 08:01 PM
  #255
madnad's Avatar
Yes, it seems to be hooked up snuggly. Wanted to take out the hose on that side to measure the vacuum but wouldn't come off.
Also, the vacuum pressure on the intake side (feeding to this 'regulator ', felt higher. But it didn't feel as much at the ' Out ' side (feeding to the EGR valve). So it might be a dampened by this. Will try to actually measure it sometime.
Old Nov 12, 2016 | 11:39 PM
  #256
tony_2018's Avatar
Fish Twig
The egr control solenoid gets activate when certain conditions are met.
Old Nov 13, 2016 | 04:42 AM
  #257
madnad's Avatar
Can they go bad? Can they be tested ?
Old Nov 13, 2016 | 05:39 AM
  #258
Well from his description you can test voltage to the plug.
THe egr system on your CVT hx seems to be very similar to the civic VX (92-95). I would imagine trouble shooting it should be online somewhere, I'll try to search in a moment
Old Dec 20, 2016 | 03:31 PM
  #259
madnad's Avatar
Waited to see what happens before giving update.
The stumble got a lot better over time and some more after topping off the coolant and removing bubbles. (Lesson: don't forget the simple things). Now it happens over a lesser range of rpm (2 to2.2k), only when warm. And will have searching idle at stop light when warm. This eventually gets better the more I drive. If this points to something please let me know.
Old Dec 20, 2016 | 06:12 PM
  #260
Still sounds like a vacuum leak on the intake manifold
Old Dec 21, 2016 | 01:37 PM
  #261
madnad's Avatar
Will try to look for leak using water spray... but this doesn't happen while in Park, only while running. So would the leak still show up?
Chev
17
Jun 6, 2018 04:22 AM
omarob18
Nov 10, 2016 10:16 AM
mynameizstitch
Mar 17, 2012 10:55 AM
JOS-EM1
12
Aug 24, 2011 07:04 PM
