Tell Us What You Did To Your EG/EK/Del Sol Today
Got a call from machine shop today. Gonna get head picked up and this evening is dedicated to getting it back on the block and the motor assembled. be another thing off the list!
98 lx @ 162k
OEM Trailing Arm bushings replaced
OEM Rear Shoes x4 replaced
Russell's braided brake lines F&R
Akebono front brake pads
Rebuild stock front Calipers with OEM caliper kit
Brake fluid drain and bled
Dorman exhaust manifold swap, stock one had common crack at O2 sensor, caused CEL
That's a clean engine bay, Chrysler Kid. Well done.
Civic402lx, how'd the trailing arm bushing replacement go? Did it take a long time? My bushings need to be replaced soon, too.
I did the following on my 6th Gen this week:
1. New Rotors
2. New Padds
3. New Drums
4. New Shoes
5. New Drum harware
6. New Clutch Master
7. New Clutch Slave
8. New clutch flex line
9. New Valve Cover Gasket
10. New Valve cover seals (plug and bolt seals)
11. New Passenger Side Lower Engine Mount
12. Oil change
For the 5th Gen project car:
1. Reconnected shifter
2. Reinstalled the axles and tightened up the suspension
3. Made a list of everything else I need to do.
1. New Rotors
2. New Padds
3. New Drums
4. New Shoes
5. New Drum harware
7. New Clutch Slave
12. Oil change
@Cx-Adam,
Pretty simple if you have the press tool. I bought one a long time ago. Air compress tool help. But not required. Anywhere from 30-45mins per side. This taking time to lign everything up. Mark your alignment bolt before removal. Get a sharpie and draw around the washer. Later you can lign it up then tighten.
I have this one:
https://www.amazon.com/Honda-Trailin.../dp/B000HI0PUK
I didn't pay that price back when..cheaper then. Had it for bout 10yrs now..
I have this one:
Yesterday:
set ride height.
pre-loaded and torqued all bolts.
New battery
new power wire from battery to amp
Finished the big 3.
Made an appointment to get it aligned.
First time it's moved on it's own power in over a year.
set ride height.
New battery
Finished the big 3.
@Cx-Adam,
I have this one:
I have this one:
didn't get the things I said I'd do because I found out the passenger seat is a 2dr and the driver seat was a 4dr. I have to do more work to remove the bottom bracket to knock out the metal tabs and bolt it to the custom brackets. So pissed.
Ebay has a part feedback system now so you can read the reviews on the part being sold, but it's the ones that are $33 shipped. Took 5 days Cali to dallas in stock
Install JDM ek side markers. I like it.
Install eBay front and rear lip. Sir replica front and type r rear.. Surprising it fit pretty darn good..
Front lip uses stock mounting point, came with 11 bolts and nuts.. 9.5/10
Rear fit pretty tight. 9.5/10.. Only used 3m double sides tape and 4 selkf tapping screws. 2 on each side of lip edge..
On with the pix for fun.
b4:
After:
Thats all for now
b4:
After:
Thats all for now
