lsv on the quest for low low 9s
Old Jul 15, 2016 | 05:15 AM
  #26
AZ_CIVIC's Avatar
Default Re: lsv on the quest for low low 9s
Originally Posted by 96ekb20
pm me if youd like to sell it with a price
Sent a PM your way.
Old Jul 16, 2016 | 02:50 PM
  #27
96ekb20's Avatar
so i know everyone said the eagles would be fine that that power but been told the rpm is limited to 9600ish i have a set of crower i beams i just got the other day there true crower not brain cower. 4340 steel billet rods with std bolts now are they better as far as rpm handling stand point as to the eagles with 2000 bolts. crower says they can handle the hp just no word about rpm.
Old Jul 20, 2016 | 08:19 PM
  #28
96ekb20's Avatar
block came in last week, ordering turbo and pistons this week and maybe fuel system if my old one sells.
Old Jul 20, 2016 | 08:24 PM
  #29
96ekb20's Avatar
whats a good scatter shield to have ? and any good cage kits? only ones ive seen and been shown is the jegs cage kits. but none are for a hatch.
Old Jul 27, 2016 | 01:04 PM
  #30
600hpdream's Avatar
my build guidence buddy said yes gsr trans with 24,5 revs to about 9300 to do 155mph, b16 revs to about 10200. to do same mph. he advised i have rev limit set to 10k on the eagles and make sure to not hit it or a rods will most likly break.
thanks for that info appreciate it.
Old Jul 27, 2016 | 03:20 PM
  #31
drmix's Avatar
If your looking for a cage I HIGHLY recommend Whitfield. It might cost a little more than some other companies but you spend so much more time making other kits fit. I bought a Whitfield for my teg and it was about 95% ready to weld in when I received it. The only thing that I needed to modify was the angle at which the rear bars connect to the floor which didnt take long at all. The main hoop already comes welded together also.
1996-2000 EK HONDA HATCH W/1.625 MATERIAL, 0.095 THICKNESS, 8/10 POINT IN DOM ? Whitfield Mfg
1996-2000 EK HONDA HATCH W/1.625 MATERIAL/ 0.083 THICKNESS, 8/10 POINT IN CHROMOLY ? Whitfield Mfg
Here is a link to my build when I received my cage from Whitfield and also some pics of when it was installed.
Drmix's 96 CGP GSR Turbo Drag Build Thread - Page 167 - Team Integra Forums - Team Integra
As for the scatter shield, I dont have any input on which one is best but I know Golden Eagle makes one as well as Dynamic Performance. I will probably get this one when the time comes.
Dynamic Performance Racing Honda / Acura Scatter Shield ? Dynamic Performance Racing
Old Jul 28, 2016 | 04:14 PM
  #32
96ekb20's Avatar
thanks for the input on the cage but decided to just bend up my own boss can get me the steel for under 150 to do a full over built 10 point. does anyone know if theres a mandated piping size on the cages? or thickness? will defiantly be buying that shield after tuning is done.
engine bay up date pistons coming in monday so block willl be bored late next week engine assembled this coming weekend. turbo will be here friday but its 110 here all week and going camping this weekend so mon night will mock up new turbo and start getting everything laid out as i have the old broken block in the engine bay.
injectors,fuel pump, top hats, clips, lsv kit, head gaskit, studs, rings, bearings, intake manifold already in and just waiting on the shelf.
thanks for all the input and guidness everyone on here has given me here at honda-tech
Old Jul 29, 2016 | 05:25 AM
  #33
jayswizz's Avatar
the nhra rule book has all the specs as far as roll cages go. section 20 page 21. fwiw i had a local guy do my 10 pt cage. he used an s&w pre bent cage, i did all the pre work for him like removing dash, seats, carpet, he did iot for $900 and i couldnt be happier with the way it turned out, fitment is 100% if not experienced with welding or bending i honestly would think twice about doing it yourself if you dont have someone to guide you. there alot of specs the cage needs to meet in order to be certified. having to cut the cage out to fix it or even start over would be an absolute nightmare.
Old Jul 31, 2016 | 07:19 PM
  #34
96ekb20's Avatar
been building dirt track cars for almost 7 years been welding since i was 15 in 24 now. i will have to look over the rules well. jegs does have some nice kits as well. from pics ive seen of cages that pass tech im sure how over built mine would be it pass all day. well more parts came in will post pics in a min.
Old Jul 31, 2016 | 07:58 PM
  #35
96ekb20's Avatar
Old Jul 31, 2016 | 08:00 PM
  #36
96ekb20's Avatar
Old Aug 2, 2016 | 08:42 PM
  #37
96ekb20's Avatar
pistons came in today took them to the shop and didnt get any pics. hoping to have some pics coming in this weekend of the short block going together. anyone have any pics of a bw366 up pipes not sure how to make one work on my car or even a down pipe to keep my exhaust.
Old Aug 5, 2016 | 07:26 PM
  #38
96ekb20's Avatar
alos needing some incite on some tires for 15x7 wheels to hook this beast up on for street duty this year car will only be close or a hair over 600 as thats all the clutch will hold right now and intercooler piping will flowcar is not low so not worried about low car issues
Old Aug 6, 2016 | 01:17 AM
  #39
king06's Avatar
What wires are those? I would use OEM or NGK. Why comedic gasket? Again, I would do OEM. Here's a rough mock up of my s366 with 4inch down pipe. Hope it helps.
Old Aug 6, 2016 | 07:55 AM
  #40
96ekb20's Avatar
they are msd yellow wires 10.2mm and because oem doesnt make a 83mm head gaskit thats why. ya im running a ram horn manifold so it seems its gone be even harder to make a down pipe fit. so looks like im going to have to go out the hood
Old Aug 6, 2016 | 07:57 AM
  #41
96ekb20's Avatar
if your selling one of those fuel rails im in the market for one.
Old Aug 6, 2016 | 11:19 PM
  #42
king06's Avatar
I would get rid of those wires. Might be a headache in the future. OEM only makes 81 and 84mm, but companies like golden eagle will hone them out to what ever size you need.
I actually just gave away the blue one lol.
As far as down pipe it shouldn't be a big deal, just make it out of 3inch.
Old Aug 8, 2016 | 07:40 PM
  #43
96ekb20's Avatar
for now im stuck with what ive got so far if i have problems on the dyno then change whats needed. that sucks.
heres some fabing update pics
Old Aug 8, 2016 | 07:41 PM
  #44
96ekb20's Avatar
back up block assembled
Old Aug 8, 2016 | 07:43 PM
  #45
96ekb20's Avatar
Old Aug 8, 2016 | 07:45 PM
  #46
96ekb20's Avatar
catch can lines will be 4 -10an lines 2 block 2 valve cover just making the two took hours so wish they where push locks
Old Aug 12, 2016 | 01:12 PM
  #47
Steeve_Civic's Avatar
yes, use NGK, they hold 900hp and more.
use OEM 83mm, your can get them at Ipg, Dp, speedfactory...
good do luck for your new setup
Old Aug 16, 2016 | 09:45 PM
  #48
96ekb20's Avatar
taking oem wires with in case but right now just trying to get fabing done to get to tuning. after that or why thats happening ill change or replace what we find as the limit right now thats the clutch as it will only hold 400 wftlbs so around 6-650whp then car will get cage and ill order all the safety mods, scatter shield new shoes gloves suite and belts. just about done with most fab work for now. block is still not done being bored to 83mm. with .0045 p2w clearance will post some pics tomorrow.
so what are some good ek mounts. i have ripped the driver side bracket top bolt whole off the inner fender area as well as the trans mount so needing some mounts that dont move so much. edit i ripped the metal of the car not mounts.
Old Aug 17, 2016 | 10:43 AM
  #49
cruizinmax's Avatar
I have a set of innovative mounts for the EK chassis. I thought they were too stiff for my street car. They are the 85a hardness. I'd sell them for 150.00 shipped if you want them.
Old Aug 17, 2016 | 07:14 PM
  #50
96ekb20's Avatar
pm me pics please. also needig a mid shaft if anyone has one oem is fine im in nor cal so closer for low shipping the better thanks.
96ekb20
Sep 16, 2016 03:17 PM
96ekb20
Sep 29, 2015 05:25 PM
Targa4Life
Jan 5, 2010 04:20 PM
laziebun
Sep 3, 2009 06:31 PM
Urugly
Sep 3, 2007 11:53 AM
