b16a2 cam gears wont line up
Old Mar 22, 2010 | 06:06 PM
  #51
-__-'s Avatar
Default Re: b16a2 cam gears wont line up
oh man sounds crazy. well make sure u have the correct injectors and alternator plugs and stuff. also, i believe OBD-0 ECU's do not look for a knock sensor. so maybe your ECU is obd1 or something idk. and u need the correct distributor for your OBD setup.
Old Mar 22, 2010 | 06:26 PM
  #52
ryanangelo212's Avatar
i had trouble deciding on what distributor to get, which could be the problem, because i know the thing ran before i got ahold of it, but the dizzy on it was broke, so really a jdm b16 obd0 is the only one that would fit yet it doesnt run right... i thought maybe even try an ls dizzy since its usdm and heard it would work?
like i said i know it ran beforehand, like able to go out on the road, i had found recent alignment slips. and the dizzy was supposedly the problem, so maybe trying a different one is worth it, but what to try...
Old Mar 22, 2010 | 07:41 PM
  #53
what im getting at is maybe that ebay dizzy is junk or off a bit...
Old Mar 23, 2010 | 02:28 PM
  #54
canadaek's Avatar
looked at your pic of that plug again not your oil pressure switch i can see it just above the filter maybe thats for your knock sensor. do you know anybody who could lend you a dizzy to try?
Old Mar 23, 2010 | 04:45 PM
  #55
canadaek's Avatar
make sure the injectors are obd0 and use a resistor box (left shock tower i think) and can you check the fuel pressure? does it have an adjustable regulator. oh ya what are you using for a map sensor? obd2b is on throttle body obd0 are on the fire wall.
Old Mar 23, 2010 | 06:06 PM
  #56
im working on getting a different dizzy to try, and will have all that info tomorrow.
Old Mar 24, 2010 | 03:30 PM
  #57
okay, there is the resistor box so thats ok, map sensor is on the fire wall, didnt get fuel pressure...
pulled the distributor and the end thing, dont know what its called, the part that goes into the motor is loose, extremely loose. i compared it to old stock dizzy and it's much looser. moves side to side more than the stock one and also moves in and out a bit. also, i can see a washer type thing moving around loose between the acual dizzy and this part im talking about. leads me to believe it might be garbage, did come from ebay...
Old Mar 24, 2010 | 05:08 PM
  #58
canadaek's Avatar
sounds like a good place to start f$*king ebay
Old Mar 25, 2010 | 05:50 PM
  #59
still no luck... cant find an odb0 b series dizzy to try.
however, i was tearning apart the old one which was totally shot to compare it to the ebay one, and found that the one the previous owner had on there was PM6, sohc crx si dizzy. does this mean anything to you??
Old Mar 26, 2010 | 05:58 PM
  #60
canadaek's Avatar
hmm didn't think you could put a d series dizzy on a b series. what's wrong with the orginal dizzy bad bearings ? or electronic's any junk yards around you ? some parts store's sell new or remained dizzy's or importers for an oem one. never asked before where are you located ?
Old Mar 27, 2010 | 02:13 PM
  #61
ok so i got an old dizzy an started swapping parts onto the new one. the module didnt fit in the new one, but, i switched the coil, and when i did i threw a code 9 which is cyp censor, so thats pretty solid evidence that the ebay dizzy is junk! still trying to find a diff one, but ill let you know how it goes.
Old Mar 31, 2010 | 04:14 PM
  #62
finally found a reasonably priced ls dizzy from a junkyard, modified it to fit the b16, and she now runs great!
Lesson: eBay is good for stickers, not distributors.
thanks to everyone who helped.
Old Mar 31, 2010 | 04:47 PM
  #63
canadaek's Avatar
cool glad to hear it's fixed . hope you enjoy it and try not to beat it to hard
Old Mar 31, 2010 | 05:36 PM
  #64
aw man neverrrrrrr haha.
asbloodrunsblak
Oct 27, 2009 07:16 AM
vttitan18
Jun 5, 2008 05:22 AM
Sam1am26
Apr 14, 2004 10:52 AM
EG6[B16A1]
Apr 27, 2003 08:19 AM
