IAC valve/sensor
Old Oct 15, 2003 | 02:41 PM
gsrcivict's Avatar
Default IAC valve/sensor
I have a 2000 itr that needs a IAC valve/sensor, is there one on a nother car that will fit it? 99 si? or are they all the same on vtec manifolds? thanx
Gabe
I also posted this on the itr board.
I need one if anyone has one laying around.
Old Oct 16, 2003 | 05:19 AM
gsrcivict's Avatar
Default Re: IAC valve/sensor (gsrcivict)
anybody? please?????????????
Old Oct 16, 2003 | 06:45 AM
IN VTEC's Avatar
I've got one I can part with. PM me.
Old Oct 21, 2003 | 05:55 PM
street dreams's Avatar
From: chillin in that city called queen creek, but homes the atl
Default Re: IAC valve/sensor (IN VTEC)
i asked the same ? a few weeks back and someone told me that they where all the same and i tried one from a d series and it fit the itr manny
Old Oct 22, 2003 | 07:09 PM
gsrcivict's Avatar
Default Re: IAC valve/sensor (streetdreams02)
just curious..........did it solve your problem? I tried one from a d series tonight and it still threw the same code. 14.
gabe
Old Oct 22, 2003 | 09:16 PM
well i just found out today that my iac was never my problem . i was using a b16a2 t-body gasket on a gsr t-b and it was not sealing properly but even before i discovered that, my iac was never throwing a code . well did u reset the ecu after switching the iac and is the iac hooked up and is the iac a 2 or 3 wire plug
Old Oct 23, 2003 | 05:09 AM
gsrcivict's Avatar
I did reset it, the one on my car is a 2 wire plug (I think) and I didnt even look at the other one car runs like **** with this problem, SUCKS!
Old Nov 2, 2003 | 06:45 PM
gsrcivict's Avatar
still throwing a code 14 and it sucks! runs like ****! I switched the iacv out with several different ones off civic and it still does the same thing. does it have to be off a itr? is there anything else that would cause the ecu to THINK the iacv is bad? thanx
Gabe
Old Nov 2, 2003 | 06:47 PM
b18c1_powered_si's Avatar
Default Re: (gsrcivict)
i have it.
Old Nov 13, 2003 | 08:26 PM
gsrcivict's Avatar
aight fellas just a lil update on my idle problem..........ITS FIXED!!!!!!!!!!! YEAAAA!!!!!!! boi am I glad that **** stopped. all along it wasnt the iacv or vacum lines, the intake manifold gasket was pretty bad. it was leaking all the way around and I gues it caused the ecu to think it was the iacv. weird if you ask me but I replaced the manifold gaske and poof! no more problems
superdelsol
Oct 19, 2009 04:23 PM
ThePeanutHatchback
Jun 14, 2008 11:39 PM
gsrcivict
Nov 13, 2003 08:25 PM
gsrcivict
Oct 14, 2003 04:51 PM
dchi_t
Mar 13, 2003 04:52 PM
