IAC valve same as?
Old Oct 15, 2003 | 02:39 PM
gsrcivict's Avatar
Default IAC valve same as?
I have a 2000 itr that needs a IAC valve/sensor, is there one on a nother car that will fit it? 99 si? or are they all the same on vtec manifolds? thanx
Gabe
Old Oct 15, 2003 | 04:00 PM
Spaceballsthelunchbox's Avatar
No Big Whoop
Default Re: IAC valve same as? (gsrcivict)
I have used EGs, EKs, DCs.
The difference is the bolt spacing, so the Efs won't work.
I know for sure Si EGs use the same one.
Old Oct 16, 2003 | 05:13 AM
gsrcivict's Avatar
Default Re: IAC valve same as? (The new Spaceballs)
so not to sound dumb but to make sure, eg=99 and above? sorry
what kinda price would you charge me for one? I need one FAST! thanx
gabe
pm me
Old Nov 2, 2003 | 06:50 PM
gsrcivict's Avatar
still throwing a code 14 and it sucks! runs like ****! I switched the iacv out with several different ones off civic and it still does the same thing. does it have to be off a itr? is there anything else that would cause the ecu to THINK the iacv is bad? thanx
Gabe
Old Nov 2, 2003 | 07:14 PM
Chris93Si's Avatar
Is this on an ITR or something else? I seem to remember when doing a swap you need to swap the pin locations of two wires (iacv and something else).
Old Nov 3, 2003 | 04:29 AM
gsrcivict's Avatar
Default Re: IAC valve same as? (Chris93Si)
it is a 2000 PY ITR. Its throwing a code 14 and idles and runs like crap! I have switched it out with 2 other iacv and it still does the same thing. I was just wondering whether or not it has to be a exact one from a itr for it or not. Im starting to think that there is something else wrong with it and its tricking the ecu to think its the iacv. anybody? I already took it off and cleaned it with brake cleaner. thanx fellas!!!!!!!!!!!!!!!! Gabe
Old Nov 3, 2003 | 09:51 AM
gsrcivict's Avatar
help!!!!!!!!
Old Nov 3, 2003 | 10:08 AM
That Dood's Avatar
Default Re: (gsrcivict)
check for vac lines
Old Nov 3, 2003 | 01:56 PM
gsrcivict's Avatar
Default Re: (That Dood)
I did check all the vacum lines and all seem fine. they wouldnt cause it to throw a check engine would they?
Old Nov 3, 2003 | 05:44 PM
No Big Whoop
If you replaced the IACV with two others and the code is still there, then you have a problem with the plug or the wires to the ECU.
Start by checking the plug on the engine harness. Sometimes the pins inside can slide back into the plug and not make a good connection. it has happened to me.
if the plug is making good contact and there is no chance of a pin not making contact at the IACV plug, then there is a problem with the wires.
Have you had an AFC installed? Have any of the wires at the ECU ever messed with? I don't know where the IACV pin is at on your OBD2 ECU. It would be worth it to check for continuity from the ECU to the plug on the engine bay.
Old Nov 3, 2003 | 06:51 PM
BlkSIvic's Avatar
whats up hector, I'm having the same problem it seems to happen about once a month . I've heard everything to vacum leaks to air pockets in the coolant sys. holla back if you find the prob.
Old Nov 4, 2003 | 06:30 AM
gsrcivict's Avatar
Default Re: (The new Spaceballs)
thanx for the help, Ill check out the wires and ecu today.
wuttup ty? where ya been? pm me man what you got in your SI now?
gabe
Old Nov 4, 2003 | 08:00 PM
gsrcivict's Avatar
anyone else got any ideas?
Old Nov 5, 2003 | 08:57 AM
gsrcivict's Avatar
Old Nov 9, 2003 | 07:35 PM
gsrcivict's Avatar
bump
Old Nov 13, 2003 | 08:25 PM
gsrcivict's Avatar
aight fellas just a lil update on my idle problem..........ITS FIXED!!!!!!!!!!! YEAAAA!!!!!!! boi am I glad that **** stopped. all along it wasnt the iacv or vacum lines, the intake manifold gasket was pretty bad. it was leaking all the way around and I gues it caused the ecu to think it was the iacv. weird if you ask me but I replaced the manifold gaske and poof! no more problems
Dc_Ek
Dec 8, 2005 03:37 PM
gsrcivict
Nov 13, 2003 08:26 PM
gsrcivict
Oct 14, 2003 04:51 PM
civicunderconst.
May 9, 2002 07:09 PM
