help me clean out my gargae!!
ENGINE/TRANSMISSION:
- B-Series
starter $45
upper timing belt bracket $10
rear bracket (eg/dc)
vtec solenoid $20
tranny shift fork $10
b16 exhaust manifold (top portion) $30
power steering pump (w/ brackets & belt) $60
ac compressor (w/ belt) $50
- D-Series
(2) rear mounts (ek) $10
(2) upper transmission mounts $10
driver side lower bracket $10
lower transmission bracket $10
rear bracket + mount (ek) $20
rear bracket (ek) $10
y8 throttle cable $15
y8 upper timing belt cover $10
y8 stock airbox assembly $35
y8 head (rear 2 valve cover bolts are broken off inside the head, easy fix) $70
y8 manual throttle body (complete) $40
y8 manual intake manifold (complete w/ fuel rail & injectors, 99-00) $60
y8 automatic intake manifold (96-98) $35
y8 stock header $20
(2) header gaskets $20
valve cover (painted wrinkle black w/ red HONDA) $40
y8 intake manifold bracket $10
manual d16y8 p2p obd2a ecu $40
manual d16y7 p2e obd2a ecu $35
energy suspension shifter bushings $15
INTERIOR:
type-k (dark gray) dashboard passenger side cover (96-00) $10
type-k (dark gray) back of steering wheel plastic cover (96-00) $10
rear seat belts (96-00 coupe) $15
type-k (dark gray) cover for top of steering column (96-00) $10
1998 cx dash harness (cut in a few places) $20
1998 cx floor harness (cut in a few places) $20
blaupunkt headunit $50
type-k (dark gray) stock steering wheel (96-00) $10
ichibahn automatic shift **** (red and silver, looks pretty cool!) $10
stock automatic shifter (96-00) $10
96-98 cupholders (no pocket) $15
96-00 automatic EX gauge cluster (gas and temp gauges dont work, will part out) $20
stock front EX seats (96-00) $40
92-95 seat rails $20
black rear seats from a 2dr integra (94-01) $20
automatic brake and gas pedal assembly (96-00) $30
type-k (dark gray) trunk plastic piece, where the trunk latch is (96-00 coupe) $10
EXTERIOR:
black datum 1 rear tow hook $50
96-00 coupe/hatch window visors $40
H4/9003 "super white" bulbs $20
92-95 stock coupe taillights $30
99-00 stock grill (black w/ chrome H and border) $30
stock red cx hatchback spoiler (96-00) $30
del sol inner fender liners (93-97) $30
99-00 spray painted red front bumper (has a crack on the bottom, not that noticeable) $30
WHEELS/SUSPENSION:
stock EX springs (96-00) $30
factory set of lug nuts $10
MISC.:
BNIB o2 sensor $60
b/d slave cylinder $20
cruise control assembly (came off my 96 EX coupe) $40
ac lines, fan, radiator (came off my 96 EX coupe) $50
ek horn relay $10
foglight relay $10
type-r badge $5
magnetic jdm badge $5
suction cup jdm badge $5
cylinder honing tool $25
megan racing high-flow cat (makes rattling noise) $20
harness to the keep factory radio for aftermarket radios for an 96-00 EX (so the keyfob will work with an aftermarket radio) $10
sony psp w/ 4 games $100
tippman 98 custom paintball gun (with goodies) $80
<U>will take trades also!!</U>
<U>paypal certified and will ship at buyers expense</U>
<U>obviously theres too many thing to post pics of. so if you want one. just let me know!!</U>
Modified by red96civicex at 2:18 PM 11/5/2008
- B-Series
starter $45
vtec solenoid $20
- D-Series
y8 stock header $20
INTERIOR:
EXTERIOR:
WHEELS/SUSPENSION:
MISC.:
BNIB o2 sensor $60
ek horn relay $10
foglight relay $10
type-r badge $5
