Go ahead and lowball! EK stuff in Minneapolis. block filler, door shells, more!
Old 05-12-2006, 07:33 PM
s1ngle's Avatar
Default Go ahead and lowball! EK stuff in Minneapolis. block filler, door shells, more!
FS:
driver side 96-98 headlight with some fogging... $12
96-98 coupe tail lights, full set... $20
Moroso block filler... $18 per jug, I have 2. Each one does about 1 honda block approx,
driver side coupe door shell (red) will come with as many moldings/weather stripping as you want .. $75 -- this door is flawless.
2 white coupe door shells, one has rust all over the bottom, not bad but is a pain... the other has some dents. $FREE and i'll deliver in minneapolis. Otherwise theyre going to the scrap yard soon.
D16y8 head with valves/springs... a cam (not sure if its the right one) and a few other misc things...$30
plastic Saab blow off valve with pipe, worked fine in my car... $10
stock Y8 fuel pump, stock Y8 fuel injectors...$best offer
Stock 96-98 civic airbox/pipe ... $10
D16Y8 crank, slightly scored and will need to be machined.... $15 ...
D16Y8 throttle body w/tps... $25
pictures upon request.
s1ngle is offline
Old 05-12-2006, 09:22 PM
hondaex00's Avatar
on $30 for the d16y8 head? Whats the catch?
hondaex00 is offline
Old 05-12-2006, 10:13 PM
s1ngle's Avatar
Default Re: (hondaex00)
umm... it doesnt come with anything but the head and valves/springs... no caps/girdle/lost motion assembly... pretty much a bare head.
s1ngle is offline
Old 05-14-2006, 01:02 PM
s1ngle's Avatar
Default Re: (s1ngle)
bump
s1ngle is offline
Old 05-19-2006, 03:16 AM
s1ngle's Avatar
bump!
s1ngle is offline
Vladglad
03-13-2014 01:54 PM
theslugbug
05-21-2008 11:01 AM
s1ngle
08-03-2006 12:24 PM
96CIVICEX
03-13-2004 03:07 PM
Quick Reply: Go ahead and lowball! EK stuff in Minneapolis. block filler, door shells, more!
