FS NorCal: Stock B16 cams, gears, JDM DC Header, Beaks, LSD
Hello All,
I'm selling the following items in used condition. I'm located in the Bay Area CA but willing to ship at buyers expense.
B16A3 Stock cams and cam gears. These came out of my USDM B16A3 (94 Del sol vtec). They have around 150,000 miles on them and some slight surface rust from sitting in the garage.
$40
JDM DC 4-1 header with 2.5" collector. This is a mild steel header so has some surface rust. I have also dented to bottom of the header from being low.
SOLD
Beaks submframe re-enforcement kit for EG/DC2. I used this kit with a 22mm ITR sway bar for 5 years, heavy track use with no issues.
SOLD!
ATS/Carbonetics metal clutch type 1.5 way LSD. This LSD needs to be either rebuilt or realignd($55 to check by Carbonetics). I have a quote from Carbonetics for them to rebuild for $760 with Carbon plates, or $345 with metal plates. You can optionally add a 45 degree cam to avoid chatter on the metal plate for $220. It includes new bearings with only 4 track days on them. So worst case scenario you get a $1,000+ LSD with new bearings for $960 or you luck out and the metal plates need to only be realigned. Also comes with new speedo gear.
$200 shipped.
$40
SOLD
SOLD!
$200 shipped.
redhanyo
02-12-2006 09:17 AM
