Doing a swap and need starter/axles and some mounts for b-series asap
Old 04-05-2004, 10:29 PM
kholmes's Avatar
Default Doing a swap and need starter/axles and some mounts for b-series asap
I need a starter
axles and halfshaft
99-00 civic SI mounts
side tranny mount
rear T bracket mount
drivers side mount connected to motor under cam gears.
Also need:
flywheel bolts
clutch bolts
throw out bearing, fork and spring, boot and slave
and heat sheild under tranny.
Thanx
kholmes is offline
Old 04-05-2004, 10:33 PM
b18c1_powered_si's Avatar
Default Re: Doing a swap and need starter/axles and some mounts for b-series asap (kholmes)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kholmes &raquo;</TD></TR><TR><TD CLASS="quote">I need a starter
axles and halfshaft
Also need:
flywheel bolts
clutch bolts
Thanx</TD></TR></TABLE>
i have it.
b18c1_powered_si is offline
Old 04-05-2004, 11:04 PM
kholmes's Avatar
Default Re: Doing a swap and need starter/axles and some mounts for b-series asap (b18c1_powered_si)
pmed you.
Also need a b20 in TX if possible
kholmes is offline
GEO276
08-28-2005 03:04 PM
Timmay
08-16-2004 05:29 PM
turboex
09-13-2002 09:27 AM
Quick Reply: Doing a swap and need starter/axles and some mounts for b-series asap
