Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Window Net
Old Apr 22, 2004 | 06:59 AM
ZUL8R's Avatar
Default Window Net
Is there a proper way to install a window net wothout a full cage? I need a few more safety items and that is one of them..Or should i just go with arm restraints?
Thanks.
Old Apr 22, 2004 | 07:03 AM
Crack Monkey's Avatar
Default Re: Window Net (ZUL8R)
Not much help, but ... I've never seen a window net installed without a cage.
I have seen arm restraints used without a cage - usually in open top cars.
What are you trying to accomplish? What car? What type of events?
Old Apr 22, 2004 | 10:40 AM
ZUL8R's Avatar
Default Re: Window Net (Crack Monkey)
well, i want to get our 98 civic coupe ready for solo 1. The kirk 4pt bar should be here friday, i will still need a net, fire bottle and a few other little things.
.RJ's Avatar
.RJ
Window nets are required for Solo 1?
Old Apr 22, 2004 | 10:43 AM
ZUL8R's Avatar
Default Re: Window Net (.RJ)
window nets or arm restraints as far as i know..
Old Apr 22, 2004 | 10:55 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">Window nets are required for Solo 1?</TD></TR></TABLE>
More to the point... cages are not required?
Old Apr 22, 2004 | 10:57 AM
ZUL8R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crack Monkey &raquo;</TD></TR><TR><TD CLASS="quote">
More to the point... cages are not required?</TD></TR></TABLE>
uh OK
Old Apr 22, 2004 | 11:00 AM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crack Monkey &raquo;</TD></TR><TR><TD CLASS="quote">More to the point... cages are not required?</TD></TR></TABLE>
I was under the impression that you needed a rollbar, belt, fire bottle, and suit.
http://scca.org/Solo/Solo1.asp...0|066&~=
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scca.org &raquo;</TD></TR><TR><TD CLASS="quote">Time Trials are defined as "speed competition on a closed course with one car at a time running against the clock for the fastest time." Roll bars, helmets and seat belt/shoulder harness combinations are required in Solo I just as they are in racing. Either a set of underwear or outer driver's suit of SCCA-approved flameproof material must be worn and the combination of both the suit and underwear, which is required in racing, is recommended for Solo I.</TD></TR></TABLE>
Old Apr 22, 2004 | 11:04 AM
Well, that quote is a bit ambiguous, as it says "rollbars are required, as in racing". Except that rollbars are not required in racing - full roll cages are required.
I have no clue what SoloI requires. I always assumed it was the same as club racing - since you are at club racing speeds.
Anyways, I still don't recall every seeing a window net installed without a cage.
If you need net or restraints, I'd go with arm restraints, since they are easily removed (assuming you are streeting car to/from track) and don't block ingress/egress.
Old Apr 22, 2004 | 11:10 AM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crack Monkey &raquo;</TD></TR><TR><TD CLASS="quote">I always assumed it was the same as club racing - since you are at club racing speeds</TD></TR></TABLE>
But you're not wheel-to-wheel
Old Apr 22, 2004 | 11:24 AM
JoelG's Avatar
re: scca solo I
I don't think a window net is required.
I'm sure a cage is not.
I used to have the solo I regs but lost them. They can be ordered off the scca web site. Might be worth checking the web sites of the pennsylvania hill climb assn members, like blue mtn scca. they might have the safety info posted.
THSCC doesn't require a net for their TT events. rollbar, fire bottle & suit are required.
Old Apr 22, 2004 | 11:52 AM
racerjon1's Avatar
Default Re: Window Net (JoelG)
I have seen a window net without a cage. It was attached to the door. But..this is bad (door comes open, so does net)
I am not sure that Solo Requires either, but its should be ok to use arm restraints.
Since Solo 1 is not wheel to wheel, there is "less" of a chance for a crash and only a bar is required (belts bottle, full gear are required though)
Jon K
http://www.seat-time.com
Old Apr 22, 2004 | 12:05 PM
r2x's Avatar
r2x
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JoelG &raquo;</TD></TR><TR><TD CLASS="quote">THSCC doesn't require a net for their TT events. rollbar, fire bottle & suit are required.</TD></TR></TABLE>
Unless it's changed for the 2004 season, a suit is not required for THSCC.
Diane
To OP - Go with the arm restraints. Much less hassle, not to mention I can't see how one could effectively mount a window net on a car with no cage. Door = bad idea. You could bolt it through the floor/roof with straps of some kind, but who wants to put holes in their roof to mount a window net when they have the option on arm restraints?
Old Apr 22, 2004 | 12:21 PM
johng's Avatar
Alright guys, minimum roll protection for SCCA Solo-I is a SCCA approved 4-point roll bar. The personal safety gear/fire requirements are the same as Club Racing. Window nets or arm restraints are required.
Old Apr 22, 2004 | 06:30 PM
ZUL8R's Avatar
Default Re: Window Net (johng)
thanks, Looks like im ordering some arm restraints and a 5# bottle.. One more thing,, Is a kill switch required??
Old Apr 22, 2004 | 07:18 PM
johng's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZUL8R &raquo;</TD></TR><TR><TD CLASS="quote">One more thing,, Is a kill switch required??</TD></TR></TABLE>
Recommended, but not required for Solo.
stock99si
May 20, 2007 06:30 PM
george34
Sep 27, 2006 07:23 PM
kimi.ko
Honda Civic (2006 - 2015)
Sep 19, 2006 01:13 PM
DFW
May 29, 2006 01:08 PM
crx_ef8
Nov 14, 2004 06:18 PM
