Window rubber piece?
Re: Window rubber piece? (BOOSTED RIVIL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BOOSTED RIVIL »</TD></TR><TR><TD CLASS="quote">You will have to take your window out first then just slide the rubber piece it out.</TD></TR></TABLE>
How do you take the window out?
Not sure if you have to take your window out but I didn't have to. First, take off that plastic piece thats in your second picture off, theres 3 screws holding it in place. Then just give it a tug and it should come right off.
Re: Window rubber piece? (shooitslinh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shooitslinh »</TD></TR><TR><TD CLASS="quote">Not sure if you have to take your window out but I didn't have to. First, take off that plastic piece thats in your second picture off, theres 3 screws holding it in place. Then just give it a tug and it should come right off.</TD></TR></TABLE>
The piece of the left?
Re: Window rubber piece? (DFW)
The rubber piece is to align the window so you will have to take your window out.Your window should have 2 scerw on the bottom, just lose it and take it out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BOOSTED RIVIL »</TD></TR><TR><TD CLASS="quote">The rubber piece is to align the window so you will have to take your window out.Your window should have 2 scerw on the bottom, just lose it and take it out. </TD></TR></TABLE>
how do i slide the window out after the 2 screws
After the 2 screw you could try to move the window left to right and it will just slide out but slide it out from the outside. I did this to my car more then 12 time because my car was broke in to and they expletive up my window alignment so my window alway come off track if I lower it all the way. Have some one help you hold the window before taking off the screws because sometime it will just drop after you take both screw off.
gato5254
04-02-2007 12:36 AM
crx_ef8
11-14-2004 06:18 PM
