Will this tire pass the tech inspection at an SCCA Solo 2 event?
Below is a picture of the tread on one of my tires. As you can see, it has a few missing chunks of rubber on the outer areas of the tire. Would this tire pass the tech inspection at an SCCA Solo 2 event in Southern California? I want to autocross on my current set of tires before I replace them, but I don't want to drive all the way to an event only to find out that I would fail the tech inspection.
Re: Will this tire pass the tech inspection at an SCCA Solo 2 event? (Fuuma0083)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fuuma0083 »</TD></TR><TR><TD CLASS="quote">link doesn't work </TD></TR></TABLE>
Hmm...works now. Looks like the server was down.
Re: Will this tire pass the tech inspection at an SCCA Solo 2 event? (EricUSC)
Long as there is no cord showing or obvious sign or belt seperation then it looks like you are good to go.
What's the inside of the tire look like? You might consider having the tires remounted so that's on the inside.
Just a thought.
Just a thought.
Re: Will this tire pass the tech inspection at an SCCA Solo 2 event? (emwavey)
Good 'ol chunky RE730s. Should be fine. Mine looked much worse after a few events, but they did the job.
-Adam
-Adam
Re: Will this tire pass the tech inspection at an SCCA Solo 2 event? (Floyd)
Actually, you're right. Still, looks like it handles autocrossing about as well as my RE730s did (or didn't , depending on your point of view.) They were fine for track use, but just didn't seem to like being tossed around with a 3000 lb. VW on top of them.
-Adam
-Adam
Andrew 825SM
15
10-12-2004 03:10 PM
Vitt1
10
04-20-2004 06:17 PM
