Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Wheel spacers... worth it?
Old Feb 6, 2003 | 01:50 PM
Civic44's Avatar
Default Wheel spacers... worth it?
I notice H&R have wheel spacers in 5 mm and 15 mm. I'm assuming 5 mm can be used without changing studs and 15 mm can't, right? If I used these, it would be to obtain a wider track. Is it worth it for 10 mm increase in track? What about 30mm? Or are these used only to provide clearance from rubbing against stuff and not really to increase track? I use Civic VX alloys so there is room to increase track.
Also, unrelated, is there any downside to using open lugnuts? They seem alot lighter and they cost the same. Also, do they allow you to use thicker spacers without changing the studs? Thanks.
Old Feb 6, 2003 | 02:35 PM
johng's Avatar
Default Re: Wheel spacers... worth it? (Civic44)
H&R spacers come with longer studs, that's why they're expensive. There's mixed opinions with using 5mm spacers on factory studs. You might be okay to autocross, but it'd be to your benefit to use longer studs with spacers for racing. There's really no downside to open lug nuts on a race car.
Old Feb 6, 2003 | 02:38 PM
.RJ's Avatar
.RJ
Default Re: Wheel spacers... worth it? (johng)
I paid $44 for my set of H&R 5 mm spacers (w/o lugs)
Old Feb 6, 2003 | 02:39 PM
travis's Avatar
I used 5mm H&R spacers in the ITR to help fit 225s up front, and I didn't use the longer studs. I used some open nuts to make sure I had enough bite, and then I just used the OEM nuts after that. If you're just doing it to provide a wider track, I don't think you'll see much benefit with that change alone.
Old Feb 6, 2003 | 02:54 PM
johng's Avatar
Default Re: Wheel spacers... worth it? (.RJ)
I didn't know they could be had seperately. There you go.
John -- who paid $70-something for two spacers with studs
Old Feb 6, 2003 | 02:58 PM
travis's Avatar
Is that for new spacers? I got lucky and picked up a set of used spacers without lugs for half that price.
Old Feb 6, 2003 | 03:06 PM
ghettoracer's Avatar
Banned
From: at last finally back to sweet home, sunny north cali, usa
i used 5 mm spacers because HX requires the 5 mm spacer to clear the 10.3" calipers. i have tracked the setup, it seems to be fine. but i wouldn't really do it often. better do it right and get proper wheels, or put in the spacers.
ehh? the only way you can get more threads is using the deep shank lugnuts. my 13x9 keizer's uses 1/2" spacer and has deep shank lugnuts to allow it to grab tons of threads.
open lugnuts is needed if your studs are long enough where closed lugnuts can't seat.
Old Feb 12, 2003 | 10:19 PM
JDMvtecDRAGSTA's Avatar
Default Re: Wheel spacers... worth it? (GhettoRacer)
where did you get the spacers for $44 at??
hey ghettoracer , what kind of car do you have??? i have a civic ex and my hx rims dont fit, did you use those spacers just for the clearance issue?
let me know
thanks
Old Feb 12, 2003 | 11:03 PM
Banned
Default Re: Wheel spacers... worth it? (Mr. Sparkle)
i have a 95 del sol vtec and a 94 civic si hb, both has abs with 10.3" front brakes. thus the hx requires the 5 mm spacer to clear the caliper (you can grind the caliper too). your ex also has the 10.3 brakes so you have to do the same.
Old Feb 13, 2003 | 05:49 AM
jsi's Avatar
jsi
Also, open end lugnuts are a good way to check how far the lug engages on to the thread, especially when using spacers or after-market wheels. Also, a lot of oval and drag racing classes require those so that it is possible for tech-inspectors to verify that the lugs are engaged on to the thread the minimum required amount.
ricehead
Nov 18, 2009 05:41 PM
xander1100
Feb 1, 2009 07:25 PM
B( * Y * )BIES
16
Jul 5, 2005 10:45 AM
RineRacing
12
Sep 27, 2003 09:57 AM
EKFerioHawaii
Oct 2, 2002 02:08 PM
