Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Wheel offset question
Old Mar 25, 2010 | 01:11 PM
Tomcat's Avatar
Default Wheel offset question
Can wheels that are identical in every way except for a minor difference in offset be safely mixed (one offset on the front and another on the rear) on a track vehicle? I have two sets of RSZ-Rs; one set is +43 and the other is +45. I bent one of the +43s, so I'm thinking a pair of +43s in front and +45s in the rear. The car is an ITR, and the wheel size for both rim sets is 15x7. I know some racers in Japan mix offsets but I'm not doing this by choice; I just want to know if it's safe to do this. How will this effect handling?
Old Mar 25, 2010 | 01:17 PM
Lo-Buck EF's Avatar
Default Re: Wheel offset question
i have done it. it does play with the set-up alittle but 43-45 you probably won't feel. i tried +38f, +40r and +43f, +40rear.
Old Mar 25, 2010 | 01:24 PM
Tomcat's Avatar
Thanks for your reply!
Tom
Old Mar 25, 2010 | 01:56 PM
Wai's Avatar
Wai
ProFunction/GT Motoring
Absolutely. It would affect the overall track width of the front and rear, and ITR came with different widths from the factory anyway.
Old Mar 25, 2010 | 03:44 PM
Tomcat's Avatar
Excellent, at least there will be no significant repercussions from doing this.
Old Mar 25, 2010 | 04:29 PM
VTECIntegra9's Avatar
wai has camero slicks on the front and ice-rally tires in the rear
Old Mar 26, 2010 | 06:40 PM
Bejay1's Avatar
2mm won't matter much. 10mm+ track stagger changes will start to change the under/oversteer character ie wider track to FWD will usually reduce understeer
Old Mar 29, 2010 | 06:35 AM
JETTO's Avatar
TRIAL USER
it wont matter much and handling will still remain the same
if you fit + 45 offset on all fours you'll notice that the front tires are placed much wider than the rear tires.
Type-ARR
Feb 18, 2011 05:30 AM
JDM04Si
Aug 17, 2009 06:47 AM
primaryOBSESSION
Honda S2000
12
Mar 11, 2009 09:30 AM
Curt941
Nov 22, 2004 05:25 PM
