Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
What a rough weekend at CMP.
Old Aug 6, 2002 | 08:06 AM
AdamITR's Avatar
Default What a rough weekend at CMP.
Well I'm finally back home after the 14 hour drive from CMP! We had engine troubles all weekend long. First, we had an oil line from the oil cooler routed incorrectly which was causing low oil pressure . Secondly, while installing my oil catch can prior to the weekend, I accidently re-routed the water bypass line coming off the block into the the valve cover ... basically coolant was sucked into the valve cover! Yes, this was a boneheaded mistake!!! Luckily we caught the problem quickly though. After fixing the above mistakes, we drained all engine fluids and refilled. I thought everything was fine ... but the car kept on throwing CEL #22 (Problem with VTEC activation). It's odd because the car will engage VTEC while not moving ... but about when driving a lap or so ... the CEL comes on and goes into "safe mode." I decided to call it a weekend ... didn't want to do any engine damage. Also, on Sat. I developed Heat Exhaustion prior to the race. My brother tried to drive the car in the race (at that point we thought the car was okay) but, the car threw a CEL on the parade lap and was towed to the pits. Sorry for causing a delay in the race .
Thanks to:
Warren for letting me look over his oil cooler set-up
D for helping diagnose the water bypass prob.
Elyse & Grumpy for taking me to the Ambulance for observation.
Lessons Learned:
- Check & re-check all mods done prior to race
- Test drive car prior to race weekend
- If the car is acting strange ... don't attempt to go on the track
- Buy a Tent right away
- Drink plently of Fluids!!!! If your not peeing every couple of hours ... your not drinking enough fluid!!!!!
On the Postitive Side ... Congrats to my brother Peter for putting on a good showing in PS1 in his 91 Sentra SE-R. Also, Congrats to all the Winners on Sat. & Sun.
We'll be back and running soon ... can't wait to dice it out with everyone at Lowes!
Old Aug 6, 2002 | 08:21 AM
Doctor CorteZ's Avatar
Default Re: What a rough weekend at CMP. (AdamITR)
that IS your problem right there , 20mph and above is the only time it should engage.........unless you have a remapped ECU with the speed sensor input removed for V-tec activation
Old Aug 6, 2002 | 08:26 AM
Mike_C's Avatar
Default Re: What a rough weekend at CMP. (Doctor CorteZ)
VTEC 24/7 = fast 24/7!!!
Old Aug 6, 2002 | 08:30 AM
AdamITR's Avatar
I understand ... but the car runs fine for about a lap or so ... then throws the CEL.
Old Aug 6, 2002 | 08:35 AM
.RJ's Avatar
.RJ
Adam - the car was also blowing oil out of the intake, and sucking it back in, hence the huge plumes of smoke from the back and poor idle. There was mobil1 dripping out of the air filter.
RJ - i was in grid when pete asked me to go get you guys.
Old Aug 6, 2002 | 08:43 AM
Solracer's Avatar
Adam, Glad to hear you made it back ok and are no worse for wear. Hopefully your engine gremlins will go away after this little incident
Old Aug 6, 2002 | 08:53 AM
Back in Black's Avatar
Rather OG
Actually, I'm visiting the restroom every 30-40 minutes!
Sorry for the bad luck, Adam. Glad you made it back okay
See you at Lowes!
Old Aug 6, 2002 | 03:53 PM
it would just seem to me that you have a problem with the speed sensor regardless of how it runs it SHOULD NOT crossover to the hi-cam when the car isnt moving
Aaron_Wayne17
Honda Civic (2001 - 2005)
Oct 28, 2013 04:33 PM
burnside
Acura TSX
11
Jul 8, 2009 04:43 PM
alb_accord
Feb 1, 2005 03:38 PM
Kevin
Apr 22, 2002 09:02 PM
dieselboy
Aug 10, 2001 07:55 AM
