Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
steering response...why?
Old Jun 27, 2005 | 06:24 AM
duh blacksheep's Avatar
Default steering response...why?
I'm running 400f/500r spring rates, 26/22 mm sway bars, agx shocks (maxed in front):
when i drive other people's cars, the steering is so responsive. even in a stock 99 civic dx auto, i can wiggle the steering wheel and the car instantly reacts(doesnt turn/grab, but the car is immediately reacting to input), same with the other cars ive driven; 350Z, s2k, 92 paseo. What could it be? I like how those car are twitchy and the sportier cars have awesome turn-in.
For my setup, i figured it would have been very responsive since i bought the springs off my friend's gsr, and when it was on his car, it was very responsive as well. When i want to make a sharp turn, i have to turn way early for the car to give it time to grab and actually change directions.
Is it because its a delsol and the chassis is soft? maybe the lock-to-lock turn ratio is too high?
Old Jun 27, 2005 | 06:34 AM
Def's Avatar
Def
Default Re: steering response...why? (duh blacksheep)
Check your tierods and bushings. Something could be worn out.
Old Jun 27, 2005 | 07:27 AM
fireant's Avatar
Default Re: steering response...why? (Def)
A little bit of toe out helps alot, too.
I got my front toe set to zero and marked a stripe of red touch up paint across the inner and outer tie rods. When I autocross I can turn the tie rods 90° and get some extra toe out, and boy does it help alot! The markings make it easy to get back to my normal zero-ish settings.
Old Jun 27, 2005 | 07:42 AM
.RJ's Avatar
.RJ
alignment, bushings, chassis, tires... too many factors at work
Old Jun 27, 2005 | 08:27 AM
MattD@Stoptech's Avatar
manual steering rack?
Old Jun 27, 2005 | 08:41 AM
Default Re: steering response...why? (El Pollo Diablo)
I dont have slop in my steering. When im not moving, the steering wheel still moves the wheel at small degrees. Its a delsol si, and it has powersteering.
Old Jun 27, 2005 | 09:10 AM
chjkingme's Avatar
i suffer somewhat from this...uhh...problem, and from what i can gather, the answer for me at least lies in lower profile tires and new bushings (really needs to get around to doing that damn es kit...sigh)
Old Jun 27, 2005 | 09:32 AM
.RJ's Avatar
.RJ
Default Re: steering response...why? (chjkingme)
OEM/Mugen bushings > poly kits
Old Jun 27, 2005 | 10:11 AM
chjkingme's Avatar
Default Re: steering response...why? (.RJ)
hmmmmm (scratches chin)...i'd be happy to hear your personal reasons why, as i am relatively new to this
(awaits the inevitable slap upside the head and/or 40 threadlinks)
Old Jun 28, 2005 | 07:03 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">OEM/Mugen bushings &gt; poly kits </TD></TR></TABLE>
new oem &gt; ES poly right?
i thought polyurethane is superior to rubber?
Old Jun 28, 2005 | 07:11 AM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by duh blacksheep &raquo;</TD></TR><TR><TD CLASS="quote">i thought polyurethane is superior to rubber?</TD></TR></TABLE>
Do you believe everything you hear from people trying to sell you something?
Old Jun 28, 2005 | 07:39 AM
ryan12321's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">Do you believe everything you hear from people trying to sell you something? </TD></TR></TABLE>
Same goes for here.
Do you believe everything you hear on a forum. There are mixed opinions on bushing types.
Old Jun 28, 2005 | 11:31 AM
AutoXer's Avatar
Absolutely So how much more are the OEM bushings compared to the poly? I was considering Poly because of the cost, but don't like the longevity of the poly or the extra noise.
Old Jun 29, 2005 | 06:19 AM
Default Re: steering response...why? (AutoXer)
weird...i set my front shocks to full soft, and now my suspension feels more responsive than before. THe car obviously sways more, but really turns the way i direct it
hcaulfield57
Suspension & Brakes
11
Aug 9, 2017 08:52 PM
AT_RSX_06
Sep 10, 2014 03:40 PM
jimmy051702
Suspension & Brakes
Sep 3, 2009 06:28 PM
JMelt4
Apr 27, 2007 08:43 AM
ironcheftony
Oct 17, 2003 11:16 PM
