Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
single rod race shifter - b series
Old 07-09-2008, 01:32 AM
BigAl's Avatar
Default single rod race shifter - b series
after trying all the quick shifts, short shifts and long shifts we have decided to fabricated a custom shifter and linkage for our road race b series powered Integra
by running solid mounts we can eliminate the second rod on the linkakage and firmly mount our shift box above the tunnel .
we are working on a single rod with spherical bearing under the shifter , that passes through the tunel near the bulkhead and fixes too the gearbox via a helicopter style universal
we are currently on version #2 and have modified the linkage /pivots under the shifter to keep the sideways gate reasonably close .
by using spherical bearings and quality universals we have ended up with a completely slop free shifter that will hopefully avoid the embarrasing miss shifts !
anyone else looking at anything similar ?
Old 07-09-2008, 02:51 AM
DaveF's Avatar
Default Re: single rod race shifter - b series (BigAl)
here is my home made single rod shifter
i can get a picture of the actual piece after i get home from work. i used this in my car for a few track pass's and it seemed to work ok
Old 07-09-2008, 06:00 AM
thawley's Avatar
I've heard Hasport has been making (custom??) solid mounts for exactly this purpose.
Old 07-09-2008, 07:17 AM
unrealwrc's Avatar
Default Re: single rod race shifter - b series (rota92)
I don't really understand the point of this. can some one explain? Is it just to make for faster 5th gear shifts?
Old 07-09-2008, 08:07 AM
nickrps's Avatar
Location: Roseville really smells like poo, pooo, pooo, CA
I'm hoping Brian Slames sees this thread and posts up a pic of his custom linkage. IIRC, he has both rods running up above the tunnel to a custom box. Pretty bad *** lookin'.
Old 07-09-2008, 08:09 AM
.:Made in OC:.'s Avatar
In for pics as well.
Old 07-09-2008, 01:06 PM
Ekasey's Avatar
Are you guys running a helical box or straight cut>? if so what kind of cut times are you using?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rota92 &raquo;</TD></TR><TR><TD CLASS="quote">For dave and I, it's for less mess ups and strain gaging.
But those that run shifter boxes have things different than a normal setup. Our G-force shifter wouldn't be great for RR due to it being spring loaded so from 2-3 the shifter 'falls' into place making it harder to go to 1st. Also 5th and R are locked out.
I would love to see pics of the OP's shifter box </TD></TR></TABLE>
Old 07-09-2008, 02:12 PM
mrlegoman's Avatar
Default Re: single rod race shifter - b series (Ekasey)
Sounds interesting. But I'm never in 1st or 2nd on the track. My biggest problem is trying to shift into 4th too quickly and missing it.
Old 07-09-2008, 03:40 PM
Ekasey's Avatar
I'm just curious if anyone has tried it on a helical cut box, or if it's even possible strain guaging for shift cuts that is.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rota92 &raquo;</TD></TR><TR><TD CLASS="quote">It's straight cut gears, I'm not sure if Dave has his hooked up yet, but I certainly don't haha
So can't help there </TD></TR></TABLE>
Old 07-09-2008, 04:37 PM
B18CXr's Avatar
Stock setup works just fine... shrugg
Speed shifting the stock box is a waste. Unless you plan to rebuild yearly, shift slower.
Old 07-09-2008, 04:53 PM
Lo-Buck EF's Avatar
Default Re: (B18CXr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CXr &raquo;</TD></TR><TR><TD CLASS="quote">Stock setup works just fine... shrugg
Speed shifting the stock box is a waste. Unless you plan to rebuild yearly, shift slower.</TD></TR></TABLE>
agreed. or dragging with a ginormous turbo, sure. get yourself a gforce or liberty trans and have a good time.
but for road racing theres no need to shift the car hard/fast.
btw jack-the original hatchcrap is still winning races
Old 07-09-2008, 11:51 PM
Default Re: single rod race shifter - b series (nickrps)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nickrps &raquo;</TD></TR><TR><TD CLASS="quote">I'm hoping Brian Slames sees this thread and posts up a pic of his custom linkage. IIRC, he has both rods running up above the tunnel to a custom box. Pretty bad *** lookin'. </TD></TR></TABLE>
You said the exact same thing i was just going to say. Hopefully ill have something like that soon.
Old 07-13-2008, 12:41 PM
eg6vtec1's Avatar
Default Re: single rod race shifter - b series (.:Made in OC:.)
Here's the shifter I made, I was going to make a product out of it but its quite expensive to produce. Recently I have came up with some cost saveing solutions though, so if the demand's there who knows. It will also have an optional carbon or fiberglass box that can be used to enclose the shifter. this could also be fitted over the factory center console for a clean look for the daily cars.
How does it feel? well its very tight , No play at all. The throw is adjustable and is similair to your average short shifter minus all the play.
Old 07-13-2008, 08:48 PM
Default Re: single rod race shifter - b series (eg6vtec1)
Brian has such crazy ideas for projects its insane! He just thought of an idea once i told him about this thread in a snap of a finger... Hopefully this project goes through.
Old 10-27-2008, 02:57 PM
GroundZer0 336's Avatar
i would really like to see more pics of this. especially the bottom part.
Old 10-27-2008, 03:13 PM
275Performance's Avatar
Default Re: single rod race shifter - b series (GroundZer0 336)
Is that shifter/linkage attached to a OEM tranny configuration?
Old 10-27-2008, 09:45 PM
Default Re: single rod race shifter - b series (275Performance)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 275Performance &raquo;</TD></TR><TR><TD CLASS="quote">Is that shifter/linkage attached to a OEM tranny configuration? </TD></TR></TABLE>
Yes, i believe it is still connected to all oem locations. I will ask Brian about this.
Old 10-28-2008, 06:02 PM
Aquafina's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rota92 &raquo;</TD></TR><TR><TD CLASS="quote">Mfactory is making a semi helical set, I'm sure someone will try it at some point. I'm no tranny guru but I can't picture how it would work.
I just flat footed my stock trannies, although I understand that may be difficult/hard to do for laps on end lol</TD></TR></TABLE>
The MFactory close gear sets are semi-helical and use stock syncrho engagement. The PRO gear set is straight cut and uses stock synchro engagement. The PRO dog engagement has not been released yet. The only benefit I see using it on a track car would be the ability to shift during cornering without unloading the car as much as with syncrho engagement. The PRO dog ratios are 2.786, 1.900, 1.430, and 1.1. A lower final drive would be needed and you still have to clutch for upshifts to 5th gear. Having said that, I don't see there being an advantage for any US track car to use the shelf PRO dog set.
Old 10-28-2008, 10:23 PM
Ridin Dirty in Cali
dirty19's Avatar
Wow some impressive work there!
What does something like that cost to build if you were selling them?
Old 10-29-2008, 05:48 AM
My Name is Nobody
MSchu's Avatar
Default Re: single rod race shifter - b series (dirty19)
Up
Old 10-29-2008, 07:49 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dirty19 &raquo;</TD></TR><TR><TD CLASS="quote">Wow some impressive work there!
You are looking at around $400.
Old 10-29-2008, 01:23 PM
STN_Pat's Avatar
Why ?
Old 10-29-2008, 01:26 PM
RedneckRicer's Avatar
anymore pix of that setup. under car or how the rods actually look to the trans? i need something to keep the slop outta my steering
Old 10-31-2008, 10:09 PM
4DRmafia's Avatar
does it still have the reverse gear? I'm new to this kin d of stuff and would like to build track car later on.
Old 10-31-2008, 10:19 PM
i would think it would have a reverse gear. just altering the stiffness/accuracy of the shift
hondaspeed305
11
10-28-2008 11:25 AM
GRAMIREZ5
72
08-30-2007 05:59 AM
Extreez
12-08-2006 06:08 AM
BSERIEuS
08-25-2005 09:07 AM
willyboyK20
06-04-2002 10:58 PM
Quick Reply: single rod race shifter - b series
