Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
rule interpretation time...
Old Jan 8, 2004 | 09:47 AM
Greyout's Avatar
Default rule interpretation time...
"The factory dash board must remain intact but may be modified to fit the roll cage"
I interpret the 'dashboard' to be the flat, vinyl board that you can touch from inside the car, not including the plastic structure that it and the HVAC system is screwed into.
appropriate or wrong?
also -
can electric controls be moved / replaced? Can i re-wire the headlights, or move the wiper controls? Do I have to keep the steering coloumn stalks? (lights/wipers controls?)
Old Jan 8, 2004 | 10:24 AM
Mike_C's Avatar
You're really not going to get a definitive answer here, just a bunch of speculation (which you already have). You might as well just go straight to the man in charge.
Old Jan 8, 2004 | 10:38 AM
MattD@Stoptech's Avatar
Default Re: rule interpretation time... (Greyout)
For the record, I've asked Karl a similar question last year regarding glove comparments...and the answer was the the glove box IS part of the dash and thus CANNOT be removed...
Dunno if that has changed in anyway
Old Jan 8, 2004 | 10:47 AM
Greyout's Avatar
Default Re: rule interpretation time... (El Pollo Diablo)
I was told the glove box can be removed...
I guess the only real answer is don't undo anything you can't put back together
Old Jan 8, 2004 | 11:21 AM
Crack Monkey's Avatar
IMO, the dash is the piece you can touch and all of the supporting structure underneath.
The HVAC is not part of the dash, but usually has it's own set of rules (ie AC can be removed, heater core must remain, whatever). If the rules don't specifically allow removal of HVAC controls, then they must remain.
Glove box is one of the very areas. Some people consider it a storage bin, which is allowed to be removed under the ITCS. Others consider it part of the dash and not allowed to be removed. I am unsure if the Comp Board has ruled on this issue, but I do know it is asked frequently on the IT.com forum.
Center consoles that can be removed without cutting may be removed, but those that are molded as one piece with the dash may not be removed.
Steering column controls may not be removed unless explicitly allowed. However, in the name of safety and convenience, rewiring is usually permissible (assuming old controls and harness remain).
Old Jan 9, 2004 | 05:22 AM
Track rat's Avatar
Default Re: rule interpretation time... (Crack Monkey)
If the the roll cage's dash bar interferes with the glove box, my interpretation is that box is legally gone.
rayrayx11
Oct 14, 2013 05:18 AM
FLA$HY_5SiX2
Nov 7, 2011 04:49 PM
ella94
18
Apr 2, 2006 08:47 AM
spoonInspired
Jul 29, 2005 06:53 AM
apexinghonda
Jan 7, 2005 05:05 AM
