Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
roll cage question
Old Jan 17, 2003 | 12:24 PM
hulkhb's Avatar
Default roll cage question
what size tubing is the best to use so its "legal" ?
tia
Old Jan 17, 2003 | 12:29 PM
JeffS's Avatar
Default Re: roll cage question (hulkhb)
That depends on the weight of your car, and the series you wish to race in.
Old Jan 17, 2003 | 12:35 PM
.RJ's Avatar
.RJ
buy a rulebook for the series in which you intend to compete.
Old Jan 17, 2003 | 02:04 PM
hulkhb's Avatar
Default Re: roll cage question (Indecisive.RJ)
well the reason i ask cause i don't know squat about autox yet( i am sure thats obvious) and have the oppertunity to get a cage built for cost of materials. all i want is a four point, nothing big, car will still be a daily driver.
info :
civic hb 1998
semi gutted - weight unknown
B18C5 with intake, test pipe, exhaust, exedy clutch, short shifter.
so i don't know what class that'll put me in. Overall i want the cage to be useable for drag racing too. although i don't think i'll ever get the car THAT fast but it'd be nice to have a USE for it.
whats the piping sizes you guys use and wall thickness of the metal.
thanks
Old Jan 17, 2003 | 02:08 PM
.RJ's Avatar
.RJ
A 4 point roll bar will require no re-classification of the car on your part - legal in stock and a good idea if you ever take it to the track. Look at the Solo I rulebook for cage specs.... you should built it to that spec to be safe.
Drag racing specs and Solo I/II specs are often different.
Old Jan 17, 2003 | 10:22 PM
johng's Avatar
info :
civic hb 1998
thanks
Minimum tubing sizing from the GCR (SS, IT & T spec full cage):
1501-2200 lbs. 1.500 dia x .095 wall DOM/Seamless
2201-3000 lbs. 1.500 dia x .120 wall DOM/Seamless
Good luck.... after all, you did mention you have a short shifter.
mnneon
Welding / Fabrication
Mar 4, 2007 07:07 PM
EleanoR
10
Nov 2, 2005 03:36 PM
bb6h22a
Jan 7, 2004 09:37 PM
6ghatch
25
Dec 23, 2003 10:58 PM
ClubSiRacer
May 5, 2003 03:54 PM
