Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Roll Bar
Old Apr 17, 2003 | 12:41 AM
EF8VTEC's Avatar
Default Roll Bar
Hi guys i just recently started autocross and i think its great, I'm geting ready for streets of willow hopefully in may! I was wondering if any of you would have sketch or list of parts, as well as dimensions/thickness and what kind of pipe to use when making roll bar!
It would go in a 88-91 CRX Si
Pictures would also be appreciated.
Old Apr 17, 2003 | 02:03 AM
urbanlegend21's Avatar
New User
Default Re: Roll Bar (EF8VTEC)
do you know anything about welding or the physics behind a roll bar? A lot of run groups frown on homemade jobs
Old Apr 17, 2003 | 05:22 AM
Crack Monkey's Avatar
Buy a premade bar - much easier and isn't expensive at all ($300-$500).
Kirk Racing and Autopower are the two most common brands.
Old Apr 17, 2003 | 05:25 AM
jc836's Avatar
Unless you have built one and had it approved in the past-I will echo and urge you to contact KIRK Racing Products or Autopower. Also get yourself a copy of the SCCA General Competition Rules. You say you are doing autocross-so get the rules governing SOLO competition. SCCA can be reached at 1-800-770-2055.
The required tubing is either DOM or ChromeMoly steel. Diameter and wall thickness are determined by the weight of the car. Contstruction/design is determined by the class and category of competition. The manufacturers I mentioned are both well versed and you need to call them as awell. Don't do this without proper planning.
Old Apr 17, 2003 | 07:13 AM
gsirnj's Avatar
Default Re: Roll Bar (jc836)
I highly recommend using Kirk Racing Products for cages and bars. I ordered my cage in mid-March and it took only two+ weeks to ship. I consider it almost a custom cage because there are so many options to add. I got dual door bars, X brace and bunch of bracing within the bars. The fit is good.
Julie, who generally answers the phone and replies on e-mail was really knowlegeable and pleasant to deal with.
Old Apr 17, 2003 | 07:26 AM
Lo-Buck EF's Avatar
Default Re: Roll Bar (gsirnj)
def. buy one. its just easier. i have an autopower in my ef and the fit is pritty good(considering my car isnt straight ) there is actually a group buy goin on with a drift group on the east coast for autopower stuff. i think theyre doin the bass order and it would be shipped direct to you. check out http://www.dgtrials.com/ for the group buy info.
*edit-the site is down for some remodeling right now, but should be up later today. if not, im me and ill get u the info
-spenc
Modified by SOLOef at 11:46 AM 4/17/2003
Old Apr 17, 2003 | 08:06 AM
Lo-Buck EF's Avatar
Default Re: Roll Bar (SOLOef)
https://honda-tech.com/zerothread?id=475418
this guy has one for sale for $150
Old Apr 17, 2003 | 08:51 AM
Audipwr1's Avatar
thank god i read this post, just emailed that guy for the cage
Old Apr 17, 2003 | 09:03 AM
Evan55's Avatar
If you are an experienced welder and have access to the fabrication equipment, there really isnt any reason not to make your own. Just do your homework, study some CRX rollbars and replicate. There really isnt any magic voodoo involved in a rollbar.
however, this is not a regular old DIY job, so if you dont know how to weld or fabricate then an autopower is by far a better choice. and to be honest, if you knew how to weld or fabricate, you would not be asking this question and would have already built one.
Old Apr 17, 2003 | 03:05 PM
EF8VTEC's Avatar
Thanks so much u guys are great! Thanks for all the info!
Tyson
Aug 10, 2010 01:52 AM
allmtrdc4
Mar 12, 2006 05:34 PM
KStuned
15
Oct 3, 2003 05:44 PM
skrewdlude
Jul 23, 2003 12:23 PM
