Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Road Race engine builds
Old Dec 16, 2013 | 08:02 AM
HellaFab's Avatar
Default Road Race engine builds
Do any of you guys do anything specific for road race engine builds that you might not do if you were doing street or drag engine builds?
I know its a really open ended question. I have done a few street builds before but never a looser road race build.
Didn't know if some things get more priority with these engines... like smoothing the casting on the interior walls of the engine or bearing coatings for example.
Matt
Old Dec 16, 2013 | 11:56 AM
0.o slow 1.6's Avatar
Default Re: Road Race engine builds
Anything that wont blow up.
Old Dec 17, 2013 | 08:16 AM
VTECIntegra9's Avatar
Old Dec 17, 2013 | 08:44 AM
dirty19's Avatar
Ridin Dirty in Cali
We build the engines in accordance with the sanctioning body that we run with CCR's
Question is too vague
Old Dec 17, 2013 | 10:12 AM
mattbatson's Avatar
Matt
I balance the valves
and you should shot peen everything...worth a few hp
Old Dec 17, 2013 | 11:47 AM
Agent_Smith's Avatar
Originally Posted by mattbatson
...you should shot peen everything...worth a few hp
What exactly are you shot peening? & HOW exactly is it worth ANY HP?
I can see shot peening Rods for strength, but then I would assume your running stock rods and then I would QUESTION, WHY ONCE AGAIN? I see no HP gains physically possible.
Balancing the entire rotating assembly is something i do on ANY motor build for longevity, some people overlook this. As stated previously you build the motor for the class you want to run.
Old Dec 17, 2013 | 02:00 PM
Lo-Buck EF's Avatar
ooh ooh ooh! can i answer this one???
Old Dec 17, 2013 | 03:08 PM
GEN2 LS's Avatar
Loved
I think you missed his sarcasm...
Old Dec 17, 2013 | 03:28 PM
dirty19's Avatar
Ridin Dirty in Cali
I cant wait to hear this Spence
Old Dec 26, 2013 | 02:52 PM
1998GsRIntegra's Avatar
Please share Spence
Old Dec 29, 2013 | 02:35 PM
eastbay92cx's Avatar
Building for reliability rather than max horsepower. Fine tuning and getting the most out of parts available for the class rules.
One 20 minute race is the same amount of run time as 100 12 second passes.
Old Dec 29, 2013 | 02:50 PM
johnjw's Avatar
we built our's to oe specs. last year did over 10,000 race miles and never burned any oil. crazy huh.
Old Dec 29, 2013 | 03:56 PM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
Sounds like you need a Spoon engine, overnight from Japan.
All kidding aside though, why not just blueprint an engine and go with it?
Old Jan 2, 2014 | 11:33 AM
Redcivic92's Avatar
HT White Ops
Spencer's engine building secret is........buy a junkyard motor and run the hell out of it.
Old Jan 8, 2014 | 06:10 AM
Ev's Avatar
Ev
This....
Old Jan 11, 2014 | 08:16 AM
Lo-Buck EF's Avatar
DAMIT ERIK! KEEP YOUR LIP SHUT!!!
Thats it tho. I've done all out 10/10ths builds and ran engines from jdm importers that were stone stock. i've had much better results with the stock ones. maybe one day once i get everything else figured out, i'll do another 10/10ths engine build knowing what i know now. but for now, throw an engine in with all the bolt ons and let it eat. i throw on a fresh oil pump, water pump and upgrade the valve train if im gonna rev it (9300 in this current engine).
Power isn't everything.
Old Jan 11, 2014 | 08:43 AM
VIPperformance's Avatar
Same as any other engine for the most part, we use alot more blue lock tight on things first off things tend to get loose due to more heat and vibration. Our engine of choice is D-series..ohh yes the underdog! a wrecking yard engine will only give about enough power to pass a clapped out Volvo or VW on the round'e round'ed. Unsuspecting to most you can make a D16 put out what a relatively stock GSR would put out. Here's a few things we do... Knife edge crank, looser bearings, oil cooler, ported oil pump, extra baffling in oil pan, higher final drives in the gear box. The tune is also a little more conservative, timing is a little less aggressive and fueling is just a little richer in high load areas. Overall alot of things are about the same when it comes to building a race car drag or road racing.. lots of time lots of money but lots more seat time if your road racing!!
humble2
Oct 30, 2004 11:44 AM
humble2
Oct 28, 2004 10:46 PM
humble2
Oct 28, 2004 07:43 PM
mercury
Sep 5, 2001 12:10 AM
