Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Resistor on Kill Switch
Old Oct 2, 2006 | 04:06 PM
Aahj's Avatar
Default Resistor on Kill Switch
Alright, I just installed a kill switch on the CRX. It's one of those nifty ones like this:
I installed the resistor on the "W" side of the kill switch. It's the one that's normally a closed circuit.
I hooked everything up today and tested it. I noticed that as soon as I kill the power with the switch the resistor gets extremely hot.
Is that normal? What's the dilly?
AJ
Old Oct 2, 2006 | 06:16 PM
Chris F's Avatar
Default Re: Resistor on Kill Switch (Aahj)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aahj &raquo;</TD></TR><TR><TD CLASS="quote">Alright, I just installed a kill switch on the CRX. It's one of those nifty ones like this:
AJ</TD></TR></TABLE>
No! Bad!
Resistor will get smokin' hot if it has 12V.
I hooked mine up without the resistor.
Big switch kills the battery
Small switch kills ignition, so the motor will die even with the alternator spinning. Legal enough, functional.
Old Oct 2, 2006 | 09:26 PM
Rudaluda's Avatar
hey post some pics please
Old Oct 3, 2006 | 05:38 AM
577HondaPrelude's Avatar
Default Re: (Rudaluda)
The big terminals (Normally closed) goes between your battery and the main fuse box.
1st little terminals (Normally closed) goes in line with the main ignition wire.
2nd little terminals (Normally open) is an added wire that goes from your alternator output to one side of the switch and the resister to ground on the other side.
when the switch is off: You are cutting the battery to car connection off, cutting the ignition off, and shorting the alternator to ground via the resistor.
To be completely legal you will also have to move the starter wire to go from the main fuse box battery input to starter, rather than from the battery to starter. This is because you should not have 12v anywhere in the car (even the starter), other than at the cut off switch if the switch is off.
Old Oct 3, 2006 | 06:44 AM
Chris F's Avatar
Default Re: (577HondaPrelude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 577HondaPrelude &raquo;</TD></TR><TR><TD CLASS="quote">The big terminals (Normally closed) goes between your battery and the main fuse box.
As long as he cuts the battery right at the "+" terminal of the battery, and kills ignition, it'll be legal. I didn't move any wires, just took the Battery + to the kill switch, and back to the original + lead. I tried it without cutting ignition, but that didn't work, the alternator did keep the car alive.
Old Oct 3, 2006 | 07:19 AM
Default Re: (Chris F)
just as long as battery power goes though the switch before it go to the starter and the main fuse box you are legal. Some people leave the direct connection from the battery to the starter and if you get nit picky that is not legal per the rules because something in the car (the starter) still has electrical power. That's what I was trying to say before.
You don't really need to ground the alternator output via the resistor to cut the car off this is just to ensures you don't have any stray voltage potentials at any point in the car. This way if a tech inspector starts poking around with a volt meter, after cut off, you're 100% safe because every thing has a path to ground (other than the battery its self).
Old Oct 3, 2006 | 02:53 PM
Aahj's Avatar
[Carlos Mancia retard voice]"Dun DaDahh"[/Carlos Mancia retard voice]
Fixed. Thanks for all the help. I'll have to post some pics soon because I think it looks pretty slick where I installed it.
AJ
Old Mar 25, 2007 | 06:01 PM
mrlegoman's Avatar
I'm going through your old post AJ. I just bought a kill switch exactly like yours off of eBay. I installed it this weekend, wiring up just the + battery terminal. Have not tested it yet.
Post some pics!
Old Mar 25, 2007 | 06:21 PM
Aahj's Avatar
Default Re: Resistor on Kill Switch (mrlegoman)
here j00 go
Old Mar 25, 2007 | 06:34 PM
thawley's Avatar
Old Mar 27, 2007 | 06:22 PM
tom91ita's Avatar
Banned
read this and use the link to my 86 crx si wiring photos of schematics
http://itforum.improvedtouring...witch
Modified by tom91ita at 4:16 AM 3/28/2007
Old Apr 3, 2007 | 06:28 PM
JOE BD-0's Avatar
Default Re: (tom91ita)
If my memory serves me right....(watch out...)....One of the main (race) techs at American Honda told me that you only need to interrupt the battery wire.....this proved true, when my battery wire came off, the car abruptly died.....also, if you should accidentally hook up your battery wrong, those fancy ones can fail internally, and end up not working at all, I know this because......oh well, good luck...........
Old Apr 3, 2007 | 06:34 PM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrlegoman &raquo;</TD></TR><TR><TD CLASS="quote">I installed it this weekend, wiring up just the + battery terminal. Have not tested it yet.</TD></TR></TABLE>
It won't work!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JOE BD-0 &raquo;</TD></TR><TR><TD CLASS="quote">If my memory serves me right....(watch out...)....One of the main (race) techs at American Honda told me that you only need to interrupt the battery wire.....this proved true, when my battery wire came off, the car abruptly died.....also, if you should accidentally hook up your battery wrong, those fancy ones can fail internally, and end up not working at all, I know this because......oh well, good luck...........</TD></TR></TABLE>
I've run my car without battery connected. It didn't flinch, not one bit.
Old Apr 3, 2007 | 06:39 PM
slammed_93_hatch's Avatar
Default Re: Resistor on Kill Switch (Chris F)
over on nasaforums.com in the HC section there is a really good write on how to do it.
I just had to re-do mine since it wasn't technically legal but would still kill the car when switched off.
Bludger
Sep 26, 2010 07:57 AM
eL_cArLos
Feb 20, 2008 06:19 PM
Supremacy
Mar 19, 2005 04:11 PM
crewjones
Oct 27, 2003 06:51 AM
