Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
remove under coating?
Old Nov 21, 2006 | 10:02 AM
577HondaPrelude's Avatar
Default remove under coating?
Anyone remove that thick black tare under coating stuff from there race car? The stuff in the tire wells ect.. How much did it all weight? How did you get it off? Does the dry ice trick work on this stuff?
Old Nov 21, 2006 | 10:08 AM
.1type.'s Avatar
Default Re: remove under coating? (577HondaPrelude)
good question... ... i would like to know too.
Old Nov 21, 2006 | 10:09 AM
Andrie Hartanto's Avatar
the dry ice trick is kind of hard as you will have to pretty much flip the car upside down.
The heat gun and scraper works well. Hard work, but IMHO, works better than the dry ice.
If you can take everything out, go media blast it.
Old Nov 21, 2006 | 11:13 AM
slammed_93_hatch's Avatar
Default Re: (Andrie Hartanto)
i have done it to two cars, the heat gun and scraper method works ok, but the stuff stinks really bad when it burn.
We ended up just wire wheeling it all of. It is a time consuming proccess but you gota do what you gota do
Old Nov 21, 2006 | 12:04 PM
CompressionFed's Avatar
Default Re: (slammed_93_hatch)
I've done this as well...be prepared to spend a full weekend removing from under the car. We weighed the mess that came off...right around 35 pounds. Not much of an improvement if you consider every 100lbs lost is worth .10/sec (atleast in the 1/4 mile)
FYI, the stock wiring in a CRX also weights about 35lbs
Old Nov 21, 2006 | 12:51 PM
Another Drew's Avatar
Default Re: (CompressionFed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CompressionFed &raquo;</TD></TR><TR><TD CLASS="quote">Not much of an improvement if you consider every 100lbs lost is worth .10/sec (atleast in the 1/4 mile)</TD></TR></TABLE>
So if I can take off 1,600 lbs, I can do the 1/4 mile in 0 seconds flat?
Old Nov 21, 2006 | 12:58 PM
Ekasey's Avatar
Default Re: (Another Drew)
you need this to do that job
http://buy1.snapon.com/catalog...talog
Old Nov 21, 2006 | 04:31 PM
redzcstandardhatch's Avatar
something different
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Another Drew &raquo;</TD></TR><TR><TD CLASS="quote">So if I can take off 1,600 lbs, I can do the 1/4 mile in 0 seconds flat? </TD></TR></TABLE>
only if you run the 1/4 in 1.6 seconds right now.
Old Nov 21, 2006 | 07:37 PM
Track rat's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 577HondaPrelude &raquo;</TD></TR><TR><TD CLASS="quote">Anyone remove that thick black tare under coating stuff from there race car? </TD></TR></TABLE>
Oh, just leave it Walt. You really don't need to get that 'Lude any lighter!
Old Nov 21, 2006 | 08:16 PM
Lo-Buck EF's Avatar
Default Re: (Ekasey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ekasey &raquo;</TD></TR><TR><TD CLASS="quote">you need this to do that job
</TD></TR></TABLE> thats what my friend used on his car. borrowed it from work and it does the job for sure. just be sure to wear long sleeves and a mask as that tar can get pritty hot.
Old Nov 22, 2006 | 12:13 PM
HapaHaole's Avatar
Default Re: (Lo-Buck EF)
I believe I took about 35 #s as well off my EK scraping all that rubber undercoating off. That was fun without flipping the car over.
Old Nov 22, 2006 | 01:58 PM
Kouki-EK9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redzcstandardhatch &raquo;</TD></TR><TR><TD CLASS="quote">only if you run the 1/4 in 1.6 seconds right now. </TD></TR></TABLE>
lol, I think you broke Math Drew.
Old Nov 22, 2006 | 06:26 PM
dohcdelsol's Avatar
Default Re: (Kouki-EK9)
i was talking to a buddy about this. he was doing it the hard way on his civic with a wire wheel. someone suggested that they make like a hot tank cleaner thats pretty big and you actually dip the car into it. it melts everything but the metal.
dont know if the guy was full of bs or not but i never really looked into it.
Old Nov 22, 2006 | 06:27 PM
Default Re: remove under coating? (Track rat)
IIRC its different from car to car. The VX has alot less then say an acura does.
we took a crap load off of two 04 tsx's didn't weight it though.
Old Nov 25, 2006 | 05:01 PM
hybrid_KJ's Avatar
used a pressure washer before. Took it right off in ten minutes.
Old Nov 25, 2006 | 07:37 PM
chrisw85's Avatar
Default Re: (dohcdelsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcdelsol &raquo;</TD></TR><TR><TD CLASS="quote">i was talking to a buddy about this. he was doing it the hard way on his civic with a wire wheel. someone suggested that they make like a hot tank cleaner thats pretty big and you actually dip the car into it. it melts everything but the metal.
dont know if the guy was full of bs or not but i never really looked into it.</TD></TR></TABLE>
strip to bare chassis and acid dip. then repaint. but i wish you could do what some so and just buy a bare shell from honda/acura.
Old Nov 25, 2006 | 07:55 PM
thawley's Avatar
Default Re: (chrisw85)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chrisw85 &raquo;</TD></TR><TR><TD CLASS="quote">strip to bare chassis and acid dip. then repaint.</TD></TR></TABLE>
I'm not so sure that service is still available. At least not in CA.
Life is just as toxic as ever, people just seem to care more nowadays...
Old Nov 26, 2006 | 12:25 AM
Ekasey's Avatar
Default Re: (thawley)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thawley &raquo;</TD></TR><TR><TD CLASS="quote">I'm not so sure that service is still available. At least not in CA.
Life is just as toxic as ever, people just seem to care more nowadays...</TD></TR></TABLE>
Thawley it's done now as a "solution dip" or some crap not the same stuff as an acid dip but it does the job. The Ef that you saw at L-con had that that treatment done, so it can be seam welded.
I believe if you drop the car off at L-con they return it to you bare metal clean for 1500.00 bucks or so. Hell if it's there drop it off get it dipped, seamed, caged and ready to rock.
Old Nov 26, 2006 | 04:56 AM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
strip to bare chassis and acid dip. then repaint. but i wish you could do what some so and just buy a bare shell from honda/acura.</TD></TR></TABLE>
acid dipping or media blasting is the best, and the most efficient way to remove rust, coating and paint from large, intricate body surfaces. if you are serious about making the chassis race ready, strip it, dip it, and put in on a rotisserie for media blasting, then seam weld it and repaint.
other methods could be cheaper, but IMO are more time consuming and would not be the first choice to approach the chassis clean-up.
Old Nov 26, 2006 | 07:08 AM
jsi's Avatar
jsi
Default Re: remove under coating? (hybrid_KJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid_KJ &raquo;</TD></TR><TR><TD CLASS="quote">used a pressure washer before. Took it right off in ten minutes.</TD></TR></TABLE>
I didn't do the whole underbody yet, but i sorta discovered this by accident while cleaning out the inner fenders one day. Some degreaser+press washer took the crap right off.
Now YMMV, cuz i think this probably works better on 15yr cars where all that crap pretty much dried out...
Old Nov 26, 2006 | 07:36 PM
Aquafina's Avatar
Default Re: remove under coating? (jsi)
Wouldn't the seam welding that is necessary after acid-dipping be against the rules in a lot of classes?
There is another place in Socal that does acid dipping other than L-Con. Not sure of the name, but Rick Solis has used them.
I've taken some off in the wheel wells by accident with a pressure washer.
Has anyone noticed any rust after doing this? If so, how many wet events have you done after removing it?
Old Nov 26, 2006 | 09:31 PM
chrisw85's Avatar
Default Re: remove under coating? (Aquafina)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aquafina &raquo;</TD></TR><TR><TD CLASS="quote">Wouldn't the seam welding that is necessary after acid-dipping be against the rules in a lot of classes?
Has anyone noticed any rust after doing this? If so, how many wet events have you done after removing it?</TD></TR></TABLE>
full seam welding is but i dont think that stitch welding is against the rules.
Old Nov 26, 2006 | 10:30 PM
Ekasey's Avatar
I believe you take a weight hit for this.... I only recommend who I have seen do the work from start to finish and with great success. I have walked into a number of fab shops and had this happen
Me: do you do chassi strip and seam welding?
Fabbie: Of course we do.
Me: have you ever done a complete car before?
Fabbie: no but we are willing to try!
Me
Old Nov 26, 2006 | 10:53 PM
Default Re: remove under coating? (Ekasey)
in honda challenge you can do it no weight hit at all. in IT racing its not allowed.
Old Nov 26, 2006 | 11:17 PM
Ekasey's Avatar
Default Re: remove under coating? (slammed_93_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch &raquo;</TD></TR><TR><TD CLASS="quote">in honda challenge you can do it no weight hit at all. in IT racing its not allowed.</TD></TR></TABLE>
Thanks jimmy for the clarification!
