Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Recommended toe settings?
Old Jan 31, 2005 | 09:42 PM
LX4CYL's Avatar
Default Recommended toe settings?
I want to go ahead and toe out my rear tires, and maybe the front tires when I get an alignment in a couple of weeks.
Here's my current setup (used for daily driving and AX)
2002 Accord Sedan 4cyl (~3100lbs)
205/60-15 Yoko ES100s
19mm rear swaybar (looser than 16mm stock)
Camber adjustable front UCAs
~3.2* caster (can possibly increase to 3.8*)
-0.7* front camber (max)
-0.5* rear camber (not adjustable)
0.0" front toe
1/16" rear toe in (it used to be 0 until I got a free alignment when doing frame repair)
I will have the rear trailing arm mounting point marked with white paint so I can alternate between 0" rear toe and X/X" rear toe out with ease (so my mom or dad won't accidentally drift the car if they borrow it).
It would look like this:
Should I maybe try -1/16" total toe out up front, and -1/8" total toe out in the back?
The car already is kind of loose when I brake while turning, but I'm learning to control my braking now that I installed the bigger rear sway. The car doesnt plow as much as it used to, but I'm sure the toe settings can only help, right?
Will I notice a difference between 0" front toe and -1/16" front toe out on the street? I'd hate for the car to lose it's nice highway stability...
Modified by LX4CYL at 7:03 AM 2/1/2005
Old Jan 31, 2005 | 10:03 PM
LX4CYL's Avatar
Default Re: Recommended toe settings? (LX4CYL)
Oh yeah, I forgot to mention that I'm consistently running about 40-42psi up front, and usually about 40 in the rear...
Old Feb 1, 2005 | 06:09 AM
Driven's Avatar
my recommendation:
try it.
you'll learn a lot more from trial and error than someone telling you what's best for you and your driving. I tried using a recommended setting and found it to be horrible for my driving style.
just a thought
Old Feb 1, 2005 | 09:19 AM
LX4CYL's Avatar
Default Re: Recommended toe settings? (Driven)
Alright, I'll try -1/16" front, and -1/8" rear.
I think the smart thing to do in the rear is to mark off numerous settings, like -1/16" out, along with 0 and -1/8", so I can play with all 3, and not have to go back to the shop eveytime...
Old Feb 1, 2005 | 09:34 AM
fireant's Avatar
I'd leave it at zero up front, and just try a 16th of toe out in the rear first.
Later on, after some trial and error you could try the fronts.
Morvpleez
Mar 26, 2012 05:21 AM
huge230
Apr 8, 2006 05:22 PM
AzntaggeR
18
May 1, 2004 03:21 AM
01CWITR
Aug 6, 2002 05:32 PM
albert butterbikini
Jan 29, 2002 05:48 PM
