Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
random questions
Old Dec 29, 2003 | 06:09 PM
Ninja Kitty
Guest
Posts: n/a
Default random questions
Is removing the thermostat a good way to increase cooling ?
The Benen tow hook says to mount it sandwiched vertically in the rear around the stock tow hook but is it possible to mount it horizontally through the reinforced area around the factory hook ?
Do naca ducts work if mounted upside down ?
Old Dec 29, 2003 | 06:32 PM
CRX Lee's Avatar
Default Re: random questions (Ninja Kitty)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ninja Kitty &raquo;</TD></TR><TR><TD CLASS="quote">Is removing the thermostat a good way to increase cooling ?
No, it will probably run hotter as it can let coolant move too fast and not hang out in the radiator long enough to cool properly. If you feel you need it opened, then gut the middle out of a thermostat but leave the shell in place. I just run a low temp thermostat in my racecars and some Water Wetter and they run plenty cool even on nasty hot ambient days.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ninja Kitty &raquo;</TD></TR><TR><TD CLASS="quote">The Benen tow hook says to mount it sandwiched vertically in the rear around the stock tow hook but is it possible to mount it horizontally through the reinforced area around the factory hook ?
Not sure on this, my rear is mounted sandwiching the stock loop but has never been used.
Do naca ducts work if mounted upside down ? </TD></TR></TABLE>
Meaning facing the ground but still with the leading (narrow) edge forward? Yes if there is laminar or smooth flow coming across the surface it will work on the roof, side or bottom of the car. If the airflow is not laminar such that it is coming pretty smoothly down a panel then it won't work or at least not as designed.
Old Dec 29, 2003 | 07:53 PM
Ninja Kitty
Guest
Posts: n/a
Default Re: random questions (CRX Lee)
gracias
spidermancivic
Aug 17, 2007 06:12 AM
importfanatic17
Jan 4, 2007 09:14 PM
4DRmafia
Feb 3, 2005 11:40 AM
fridexter
Nov 20, 2004 02:52 PM
