Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Quick Spring Rate Setup Question!
Old Jun 24, 2004 | 09:18 AM
11psiTurboSI's Avatar
Default Quick Spring Rate Setup Question!
I have a 00 Civic SI... I wanted to know if 448lbs in the front and 559lbs in the rear is too much oversteer for road racing and alittle auto-x??? Cuz I just ordered a set of Zeals and those are street spring rates but the 559lbs is in front and 448lbs in rear!
Thanks for any info!
Old Jun 24, 2004 | 09:21 AM
GSpeedR's Avatar
Default Re: Quick Spring Rate Setup Question! (9psiTurboSI)
I run 450/550 right now. Haven't died yet.
It's not a handfull on the street (except in snow), and you'll like the looseness on the track. Easy to rotate; not too hard to catch.
RineRacing's Avatar
Short answer, no.
Old Jun 24, 2004 | 09:22 AM
Blue Si #72's Avatar
Naw, I run 550 f and 750 r on my 2000 Si and the car handles like a dream on course. I still have the stock bars though....
I thought it would be unstable if I dropped the throttle but it's actually quite easy to keep the rear end in line.
Old Jun 24, 2004 | 09:25 AM
.RJ's Avatar
.RJ
Default Re: Quick Spring Rate Setup Question! (GSpeedR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSpeedR &raquo;</TD></TR><TR><TD CLASS="quote">I run 450/550 right now</TD></TR></TABLE>
wtf? Did you get softer springs?
Old Jun 24, 2004 | 09:26 AM
Default Re: Quick Spring Rate Setup Question! (Geratol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Geratol &raquo;</TD></TR><TR><TD CLASS="quote">Short answer, no.</TD></TR></TABLE>
No... as in it will work great?
btw I have a progress 22mm rear swaybar
Old Jun 24, 2004 | 09:27 AM
.RJ's Avatar
.RJ
Why dont you try it and see how you like it?
Old Jun 24, 2004 | 09:34 AM
GSpeedR's Avatar
Default Re: Quick Spring Rate Setup Question! (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">wtf? Did you get softer springs? </TD></TR></TABLE>
Yep. Doctor Cortez has your 600s. It probably didn't make much difference.
I also have a 22mm Progress. Car was 300x better than when I had a more tame setup. You'll like it.
Old Jun 24, 2004 | 09:37 AM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSpeedR &raquo;</TD></TR><TR><TD CLASS="quote">Yep.</TD></TR></TABLE>
Puss
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">I also have a 22mm Progress. Car was 300x better than when I had a more tame setup. You'll like it. </TD></TR></TABLE>
Interesting. I never did get a bigger rear bar on it.
Old Jun 24, 2004 | 09:43 AM
GSpeedR's Avatar
Interesting. I never did get a bigger rear bar on it.</TD></TR></TABLE>
Puss
Old Jun 24, 2004 | 09:58 AM
LX4CYL's Avatar
Default Re: Quick Spring Rate Setup Question! (Blue Si #72)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blue Si #72 &raquo;</TD></TR><TR><TD CLASS="quote">Naw, I run 550 f and 750 r on my 2000 Si and the car handles like a dream on course. I still have the stock bars though....
I thought it would be unstable if I dropped the throttle but it's actually quite easy to keep the rear end in line.</TD></TR></TABLE>
holy crap, I remember when you had 525F/550R when I rode along with you!
Old Jun 24, 2004 | 10:48 AM
RineRacing's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9psiTurboSI &raquo;</TD></TR><TR><TD CLASS="quote">I wanted to know if 448lbs in the front and 559lbs in the rear is too much oversteer for road racing and alittle auto-x???
No, as in "It will not be too much oversteer for road racing and a little auto-x"
Old Jun 24, 2004 | 10:53 AM
Big Phat R's Avatar
I run 780/900 with 26 mm rear bar.
The car is only loose if you have too much entry speed - otherwise it carves like a knife.
Your rates should be fine - just be really careful in the wet
Old Jun 24, 2004 | 02:12 PM
Default Re: Quick Spring Rate Setup Question! (LX4CYL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LX4CYL &raquo;</TD></TR><TR><TD CLASS="quote">
holy crap, I remember when you had 525F/550R when I rode along with you! </TD></TR></TABLE>
Yeah, it's even better now!
I should be at the practice on sunday. Are you going to be there? If so I'll let you ride along and see how you like the changes.....
Old Jun 24, 2004 | 02:26 PM
LX4CYL's Avatar
nope, unfortunately, due to bad grades, I am not allowed to auto-x ever again (at least during college). Although that will not stop me from secretly attending TAMSCC Auto-Xs during the semester when my parents are far, far away
Have fun at the practice!
-Pranav
vinuneuro
Suspension & Brakes
12
Jun 26, 2006 08:47 AM
Nsane1
10
Jun 23, 2005 09:04 AM
Chong
Suspension & Brakes
20
May 22, 2005 11:24 AM
BoOsTiN Dc2
Jan 14, 2004 07:29 AM
deepgreengsr
25
Aug 30, 2003 09:18 AM
