Question: Integra running 225/45/15 on +40 offset 7.5in wide rim
#27
Re: Question: Integra running 225/45/15 on +40 offset 7.5in wide rim
FYI - I have run 225/45/15 Hoosiers on my ITR with 15x7 +45mm offset Team Dynamics wheels. Front fender liners had to be removed and front and rear fenders rolled. The fronts fit fine with very little rubbing (car is lowered about 1.25" with -2.7 front and -2.0 rear camber). The rears must use extended studs and a thick 5/16" spacer to reduce, but not eliminate, rubbing on rear trailing arm. When running 225/50/15's, no spacers are needed in the rear.
When things start to smoke, you need to add clearance!
I also have a set of T.D. wheels in that offset, and my experience is the same on the front.
#29
Oh BTW, I ran Hankook RS2 225/45/15 on 15x7 40mm rims, and I didn't have to make any changes to the car (GSR). With 7.5 rims, the lip of the rim MIGHT barely touch or not touch the rear upper control arm.
got00rice
02-21-2010 12:35 PM
redGSRguy
10-19-2006 12:31 PM
upNover
01-06-2005 06:49 PM
