Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
question about reverse staggered.
Old Mar 25, 2013 | 03:11 PM
Freshdot's Avatar
Default question about reverse staggered.
If I have wheels that are 15x8 all around and wrapped in 225/45/15 all around, and slap a 10mm spacer in the front. does that help with understeer and considered reverse staggered?
Old Mar 25, 2013 | 04:15 PM
Lo-Buck EF's Avatar
Default Re: question about reverse staggered.
stagger isn't fore or aft specific.
yes, it will help with understeer.
Old Mar 25, 2013 | 05:14 PM
Chillinit's Avatar
How about a larger rear swaybar to help the car rotate or stiffer rear springs? What vehicle are you driving?
Posted from Honda-tech.com App for Android
Old Mar 25, 2013 | 05:30 PM
Freshdot's Avatar
the car is an EJ1, with buddy club N+, and ST front and rear sways 1" front and 3/4" rear. I was really just curious to know if simply running a lower offset in the front with all other specs being the same is considered reverse stag, was discussing this with a friend earlier.
Old Mar 25, 2013 | 06:19 PM
TunerN00b's Avatar
Stagger is stagger. There is no "reverse".
Considering that the front track is already wider than the rear track on most of our FWD Hondas, running a lower offset up front (what spacers do) isn't introducing a stagger.
It will increase front cornering traction though.
Old Mar 25, 2013 | 06:54 PM
qtevafrb's Avatar
Old Mar 26, 2013 | 09:51 AM
TunerN00b's Avatar
Then the answer is "no".
There is no such thing as "reverse stagger". It can't be something that doesn't exist.
Old Mar 27, 2013 | 07:38 AM
Xian's Avatar
I always considered "stagger" to be more of a tire size/wheel size thing and not particularly offset related.
Old Mar 27, 2013 | 07:48 AM
beastiebomb's Avatar
staggered fitment is different wheel sizes, not offsets
Old Mar 27, 2013 | 08:51 PM
Libertariat's Avatar
Ek Forever y0!
^ This.
If you ran a 15x9 up front and a 15x7 in the rear, I'd call that staggered.
People do this in autocross a lot in FWD classes.
Old Mar 28, 2013 | 07:51 AM
MSchu's Avatar
My Name is Nobody
^exactamundo... though we do understand what OP was trying to say.
Air pressure also is a factor of stagger.
Old Mar 28, 2013 | 07:56 AM
Xian's Avatar
I've found the amount that I drink is a factor in my stagger too...
Old Mar 28, 2013 | 11:47 AM
iwannarace's Avatar
Will wider wheels in front increase my swagger?
Old Mar 28, 2013 | 04:50 PM
Xian's Avatar
I feel like I've got substantially more swagger now that I've got 15x8's up front.
Old Jan 7, 2015 | 07:28 AM
E V Roller's Avatar
Sooo yeah, back from the dead?
Just curious, if you run wider wheels on the front, but space the rears so they appear to be flush/have the same offset to the casual observer, what effect does that have?
Does it cancel the effect brought about by the front biased stagger? (is that a better way of putting it than reversed?)
I cant seem to find out if it is the broader front track that reduces understeer, or the larger contact patch of a wider wheel/tyre up front, or both?
Old Jan 7, 2015 | 09:02 AM
KoRn_vIRuZ's Avatar
Both. A wider track reduces weight transfer and consequently increases grip. A wider contact patch increases grip directly.
Both are nice ways to reduce understeer because your are adding to the car's overall grip levels, instead of reducing them (e.g. with a stiffer rear sway bar).
Old Jan 7, 2015 | 10:03 AM
E V Roller's Avatar
A concise answer, helps to sum things up, thanks.
I suppose then that if you were to widen the rear track to balance things looks wise, it would at least partially counteract the advantage of running a wider wheel up front.
There is probably some crazy formula to get the balance just right, but too complex for me to figure out.
Not that it matters too much, driving a grandad car here, not a circuit racer! haha!
KidFrost
Apr 15, 2011 10:36 AM
V8BWARE
Honda S2000
May 15, 2006 05:28 AM
B HATCH
26
May 25, 2004 09:13 AM
Steve91
12
Jul 22, 2003 04:42 AM
[HrZn]4life
Jul 7, 2003 08:47 AM
