Quaife quick steering rack in EM1 Si?
Hi all. I'm exploring quicker steering rack options for my EM1. I was wondering if the Quiafe Quick Steering Rack and Pinion works in an EM1, or could be made to work? I've tried to search for this and can't find much.
Thanks for any help
Thanks for any help
Re: Quaife quick steering rack in EM1 Si?
This may be of help: https://honda-tech.com/forums/honda-...-rack-2422762/
Thanks!
Yes, the Integra rack has a faster ratio. The specs are on the service manuals.
Glad to help! Sorry but unfortunately I do not know the answer to your question. I just remembered reading that post a while back and searched for it.
True dat. Anybody else care to chime in? I looked in my FSM last night and it states 3.6 for P/S and 4.1 for M/S, with no differentiation between models. However, the part numbers are different between my 99 Dx and 99 Si rack. I would test it out, but, my dash is out and steering column dropped.
Si: 53626-S04-G54
DX: 53626-S04-A54
So, I held the column and turned the wheel in the Si. Then, I marked the un-installed DX rack and turned by hand. While I could have made a mistake in this process. It does appear that the SI has a 3.2 LTL and the DX a 3.6 LTL. Interesting.
Moderator
Even the master cylinder is from a Type R, and not an EJ8
Fastest way around the course is to steer as little as possible. Try some toe-out (front and rear) and tighten up the bushings. Then there's spring rates and sway bars to think about, If you have that right, then you'll understand the counter steering comment, even with a slow rack.
Just wanted to update. I have both my Dx and Si rack broken down a good bit. With both racks locked all the way to the left, there are 2 less teeth on the Si rack shaft than the Dx. I suppose one could do the Integra pinion swap on an Si rack and net a sub 3 LTL ratio.
fsp31
18
04-29-2003 05:10 PM
