Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Is this a problem?? Help.
Old Mar 10, 2002 | 07:03 PM
CHRIS 1.8's Avatar
Default Is this a problem?? Help.
My cylinder head gasket seems to be leaking. Do you think this will cause a problem on how my motor runs? Or what should I do to stop the leakage?
Old Mar 10, 2002 | 08:05 PM
.RJ's Avatar
.RJ
Default Re: Is this a problem?? Help. (only JDM)
try loosening and re-torquing the bolts first......... in order, to spec.
Ryan
Old Mar 10, 2002 | 08:08 PM
CHRIS 1.8's Avatar
Default Re: Is this a problem?? Help. (Type-RJ)
What is the order on how it goes?
Old Mar 10, 2002 | 09:11 PM
.RJ's Avatar
.RJ
Check the helms manual. I dont know honda cylinder heads 100%, i dont know if you will need special tools - some cars require a 12 point socket.
Old Mar 11, 2002 | 06:40 AM
whitney's Avatar
99% of the time oil seen at the head-block interface is actually coming from the head cover gasket or cam seals. Check those first.
Oil is pesky and it is often difficult to determine the source of leaks. But if you've never had the head off, and there isn't oil in the coolant or vice versa, and compression/power is good, it's not the head gasket.
Wait ... why is this in the comp forum?
Old Mar 11, 2002 | 06:57 AM
Crack Monkey's Avatar
Default Re: Is this a problem?? Help. (whitney)
Like he said, check the oil and coolant for mixing. This is VERY BAD!
Because we have a clue? Or at least sound like we do.
[Modified by Crack Monkey, 7:57 AM 3/11/2002]
Old Mar 11, 2002 | 07:01 AM
gsober's Avatar
i would also check to see if the cam seal is leaking. it is very common for it to leak. it is an easy fix and it will not cost that much either.
Old Mar 11, 2002 | 07:02 AM
.RJ's Avatar
.RJ
Default Re: Is this a problem?? Help. (Crack Monkey)
Lets not get ahead of ourselves....
91crx-jace
Apr 22, 2012 04:36 PM
joetho
Jan 10, 2008 03:19 PM
slowassciv33
16
Sep 17, 2006 04:33 PM
DsVtec2nrHBC
Dec 2, 2004 04:20 PM
slowricer
Aug 14, 2004 08:34 AM
