Precautions for Next Race After Overheating?
So this weekend I overheated my car. Pegged it at full hot. I lost my radiator cap during qualifying.
We put water back in the car, got a cap on it, and got it back on track and it ran fine-- getting me P1 on day 2.
I'm worried that there is residual damage that hasn't surfaced yet. My next race is in July and I want to make sure the car is reliable for then.
Do you guys have any recommendations for maintenance before the next race?
Re: Precautions for Next Race After Overheating?
wouldnt be a bad idea to pop off the head and make sure the mating surfaces on the cylinder & head are still level.
You can also try bleeding the coolant system with one these funnels: Radiator Coolant Funnel
I'd let it run through a few fan cycles and watch for continuous bubbles. A leak down test might not always pick up a blown head gasket.
Thanks for all the responses guys and sorry I took so long to get back. I am prepping the car for Lime Rock before July.
No tempearture gauge with quantitative data but the gauge was pegged.
I change it after every weekend.
I am seeing bubbles every once in a while on a consistent basis in the coolant when it's hot, but it ran fine for a 20-minute hardship session and the whole 35-minute race...so weird...
I'm also fairly certain I saw these bubbles before the overheating incident and it always ran fine. I assumed it was stagnant regions in the system causing boiling zones that are mitigated when you increase the pressure and prevent boiling.
You think it would get worse?
I am trying to avoid this....but if I have to....
Any data on how hot it got? If it was me, I would do a leak down test just to make sure the HG is still in good shape.
this is basically what I would do. I don't know what your oil change schedule is, but i would also change that because your oil was taking the brunt of the temp while it was overheating.
Just make sure that its a legit failure and not that you sent it until you ran out of gas and have to get towed, then people will joke you.
even if its slightly warped it will prob last the rest of the season since its only driven once or twice a month, right?
assuming its a full on track car and you arent driving it on the street
