Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
PLUG GAPS
Old Jul 8, 2004 | 01:11 PM
PERFDIST's Avatar
Default PLUG GAPS
I just tried opening my plug gaps to .065". The car ran great on the low end, but when I floored it, it cut out real bad. It was also harder to start.
Does running the plug gap too wide confuse the computer???
Old Jul 8, 2004 | 02:14 PM
.RJ's Avatar
.RJ
Default Re: PLUG GAPS (PERFDIST)
.065"?
Thats way too large - what motor?
Old Jul 8, 2004 | 02:22 PM
Weston's Avatar
You can't confuse the computer... Wider is generally better, but the plug gap is limited to what the ignition system can handle. When you have a larger gap, it requires more voltage for the spark to jump that gap. And as the RPM increases, the power requirements do as well (ie the coil may not have enough time to re-energize after each firing). That's why your 0.65" worked great on the low end, but cut out at high RPMs.
Old Jul 13, 2004 | 04:28 PM
Jake's Avatar
Default Re: (Weston)
Stronger Coil + Wider Gap = Good & Legal in IT ?
LandHard
Jan 16, 2021 03:18 PM
all-mtr-teg
13
Oct 23, 2011 02:08 AM
SiR Inspired ED7
Jun 16, 2009 07:29 AM
96int3gra
May 25, 2008 10:14 PM
Scharged2000GsR
Oct 14, 2003 05:05 PM
