Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Mirror setup
Old Jan 25, 2006 | 06:34 AM
Timmah!!'s Avatar
Default Mirror setup
I got to test drive the ITS datsun the other day for the first time and I noticed something I REALLY dont like. I cant see directly behind me!!!
The current setup is a foot long convex mirror on the center of the top hoop and one crappy rear view on my drivers side door... which the window net tends to block.
Does anyone have any suggestions for mirror setups?
Modified by Cobra Tim at 9:54 AM 1/26/2006
Old Jan 25, 2006 | 01:14 PM
mstewar's Avatar
Default Re: Mirror setup (Cobra Tim)
wink 5 panel is what I use..
now if I could just get it to vibrate a bit less I'd be set..
Old Jan 25, 2006 | 01:21 PM
FormulaIntegra's Avatar
Default Re: Mirror setup (mstewar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mstewar &raquo;</TD></TR><TR><TD CLASS="quote">wink 5 panel is what I use..
now if I could just get it to vibrate a bit less I'd be set.. </TD></TR></TABLE>
Ditto....on both accounts.
I'm currently using the end brackets to mount it, but I'm thinking that adding the back mounts that glue to the windshield might help.
But I love the wink mirror. I almost don't need the passenger side mirror because of it.
I also mounted a small, maybe 2" bubble mirror on my driver side mirror to help with the blind spot/area that the window net blocks. Definitely helps.
Old Jan 25, 2006 | 01:59 PM
Track rat's Avatar
Wink =
Try fabricating a small alum bracket that attaches to the middle of the wink and to the rollcage header bar. That helps kill the vibration.
Old Jan 25, 2006 | 02:16 PM
mstewar's Avatar
Default Re: Mirror setup (Track rat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Track rat &raquo;</TD></TR><TR><TD CLASS="quote">
Wink =
Try fabricating a small alum bracket that attaches to the middle of the wink and to the rollcage header bar. That helps kill the vibration.</TD></TR></TABLE>
will do.. i've got some aluminum stock sitting around anyhow I think!
Old Jan 25, 2006 | 02:55 PM
TeamSlowdotOrg's Avatar
I'm installing a 5-panel in my SM and it reaches almost from one down-tube to the other. I'll be using the windshield mount and a couple of aluminum brackets from the halo bar to hold it in place.
Old Jan 26, 2006 | 05:55 AM
Timmah!!'s Avatar
Default Re: Mirror setup (TeamSlowdotOrg)
We have a few winks hanging around... I guess Ill install it and see how it works.
Also does anyone prefer the fine mesh window nets to the conventional large webbed ones? It seems to me that the fine mesh will allow more vision to the left.
Old Jan 26, 2006 | 06:23 AM
RacerBowie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cobra Tim &raquo;</TD></TR><TR><TD CLASS="quote">We have a few winks hanging around... I guess Ill install it and see how it works.
Also does anyone prefer the fine mesh window nets to the conventional large webbed ones? It seems to me that the fine mesh will allow more vision to the left.</TD></TR></TABLE>
I very much prefer the fine mesh nets.
That reminds me, I need to order a new one!
Old Jan 26, 2006 | 07:46 AM
krshultz's Avatar
Giles, where are you, and what did you do for mirrors in the ITC car? I don't remember the specifics, but I do remember that they (the whole lot of them) were very effective.
As I recall, there was a large, wide convex up top, and two circular convex mirrors per a-pillar, mounted inside the car to the cage. Between the five (!) of them, I could always spot when three wreck miatas were divebombing me during a test day...
Old Jan 26, 2006 | 08:03 AM
Catch 22's Avatar
Default Re: Mirror setup (krshultz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krshultz &raquo;</TD></TR><TR><TD CLASS="quote">Giles, where are you, and what did you do for mirrors in the ITC car? I don't remember the specifics, but I do remember that they (the whole lot of them) were very effective.
As I recall, there was a large, wide convex up top, and two circular convex mirrors per a-pillar, mounted inside the car to the cage. Between the five (!) of them, I could always spot when three wreck miatas were divebombing me during a test day...</TD></TR></TABLE>
Nah, there were only 3 mirrors.
One 4 panel wink up top and a circular convex on each A pillar cage downtube. The car had zero blindspots.
Old Jan 26, 2006 | 08:16 AM
Timmah!!'s Avatar
My only beef with the wide convex mirror is it seems to shrink the reflection a bit. I did have the Idea to put the additional mirrors on the A pillar bars, but I didnt know how effective they would be.
Old Jan 26, 2006 | 09:13 AM
krshultz's Avatar
Default Re: Mirror setup (Catch 22)
Okay so it only *seemed* like there were five mirrors.
That setup worked remarkably well. Important in an ITC car...there's generally someone breathing down your neck pretty well everywhere.
Old Jan 26, 2006 | 09:48 AM
Catch 22's Avatar
The fact that you drove the car all year and think that there were 5 mirrors in it is sort of telling.
I wish I'd known that sooner, I would have taken all the mirrors out of the car .
b16bri
Aug 14, 2010 04:36 PM
m1northreat
Honda S2000
Oct 31, 2007 05:07 AM
85
Audio / Security / Video
Sep 15, 2006 12:29 PM
khmy2nr
13
Apr 23, 2005 11:23 PM
fso_BamBam
Jul 3, 2003 10:28 AM
