Top mount set-ups on the street.
Old Aug 13, 2010 | 10:53 AM
b16bri's Avatar
Default Top mount set-ups on the street.
I'm getting ideas for my new project (street and track) and was thinking about a topmount set-up but i dont know much about them. I was wondering if anyone heres drives a topmount set-up on the street. Or if there is drawback to running one on the street compaired to a ramhorn like my old set-up. Meaning spool,or temp issues due to location or the fact you can have two wastegates. Also I'm still unsure if i want a ramhorn or topmount i had a ramhorn but i'de like to see pics of peoples topmount set-ups.
Old Aug 13, 2010 | 11:20 AM
boostedeg302's Avatar
Default Re: Top mount set-ups on the street.
What's your setup? Topmounts shine when bolted to a high revving setup. They make lots of power up top but will slow your spool times down. You shouldnt see any temp differences vs a bottom mount and there really isnt any need for dual wastegates unless you are running a huge turbo. Thats just money that can be spent elsewhere. They do look sick and make working on the turbo a lot easier. IMO, unless you are running a setup that you plan on revving to 9k, I would go with an equal length bottom mount. Top mounts also cost a bit more but in the end, they are both great manifolds and will make great power on any setup. Really it depends on your setup and goals
Old Aug 13, 2010 | 12:15 PM
slowboy90's Avatar
i run my topmount setup on the street im actually converting to a divided t3 twin gated setup due to boost creep and he is right mine turns 9500 with a s366
Old Aug 13, 2010 | 12:17 PM
phunhaus's Avatar
I'm running a top mount and will attest to a little "laggier" than I'd like. Servicing the turbo is a lot better than a bottom mount setup IMO.
Old Aug 13, 2010 | 01:36 PM
b16bri's Avatar
My old set-up reved to 9k could have reved up to 9500 but my power fell off turbo was on the smaller side.The motor was a fully built b16 built top to bottom and made 400+ on 20psi with a full-race mani and on pump. I plan on reving to atleast 9000 again my new set up will be pretty simular to my old. B16a sleeved. built bottom end and built and ported head with eather a t3/t61 or t3/t67...gt3076r or gt35r havent decided yet trying to go for high 400 to low 500 and still have a good powerband so i think i'm going with the 30R cus i know it's a fun street turbo and on 20psi agan it should be around there ?
Old Aug 14, 2010 | 10:06 AM
b16bri's Avatar
Any one else ? or dose anyone have a good pics of there setup ?
Old Aug 14, 2010 | 10:10 AM
TheShodan's Avatar
Moderator
read this:
"Which manifold is for me?"
https://honda-tech.com/forums/forced-induction-16/why-top-mount-2152865/
Old Aug 14, 2010 | 01:18 PM
Schister66's Avatar
Man U FTW
The ONLY time i would ever use a topmount would be on a strictly track-only car. A topmount, however 'cool' they may be, isn't really a practical option since they increase lag and shift the powerband toward the upper RPMs...not exactly ideal for street driving. I've run a log, mini-ram, SLS prototype and a topmount...my best results were with the Miniram and my current manifold (which is similar to a ramhorn).
I would read the link TheShodan gave you and decide from there...
Old Aug 14, 2010 | 04:36 PM
^^listen to these guys for sure! For a street car, you really dont need anything more than a ramhorn or similar. My next manifold is gonna be a mini-ram. Seems like everyone has great results with them and for around 500 bucks brand new, you just cant beat it IMO.
KilowattBandit
Jun 27, 2019 01:26 AM
turboek1
Welding / Fabrication
Mar 9, 2013 04:33 AM
shocker911
Aug 1, 2009 06:15 AM
fso_BamBam
Jul 3, 2003 10:28 AM
