Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Longacre Toe In Tools
Old Feb 13, 2002 | 10:03 AM
siisgood00's Avatar
New User
Default Longacre Toe In Tools
Can someone check out http://www.longacreracing.com/catalo...st.asp?catid=5 and let me know which of these 3 tools listed are needed to set toe. It seems like all I really need is the toe in plates. Anyone have any expereince with these products? Hows the accuracy?
Old Feb 13, 2002 | 11:20 AM
Crack Monkey's Avatar
Default Re: Longacre Toe In Tools (siisgood00)
All you need is the plates. The drawback is the plate rests against the tire, not the rim or hub. So, if the tire is a bit out of round, the toe measurement will be off a bit.
Old Feb 13, 2002 | 11:24 AM
4doorH22's Avatar
Default Re: Longacre Toe In Tools (Crack Monkey)
$519.90? Ouch.
Old Feb 13, 2002 | 11:32 AM
JeffS's Avatar
I'm a little confused.... the "plates" are the equivelent of any other strait edge you could lay up next to you tire. It seems like you could find any number of things that would do the same thing and cost next to nothing.
Is there some benefit to them that I'm missing?
Old Feb 13, 2002 | 02:47 PM
siisgood00's Avatar
New User
Default Re: Longacre Toe In Tools (4doorH22)
$519.90? Ouch.
What! Hell no. Here is the direct link to the plates we are talking about, I just gave the link for all 3 toe in tools so everyone can check em out. Here is the plates for $59.95. http://www.longacreracing.com/catalo...id=152&catid=5
siisgood00's Avatar
New User
Default Re: Longacre Toe In Tools (JeffS)
Great question. Anyone?
Old Feb 13, 2002 | 08:16 PM
1.8DC2's Avatar
looks a little fishy to me
Old Feb 14, 2002 | 06:46 AM
Crazydave's Avatar
Default Re: Longacre Toe In Tools (1.8DC2)
The best is the toe bar... for $82
You lift the car up... spin the tire.. and scratch a line in the front tires...
then set the car down... and settle the suspension.. then measure the distance between the line from the back of the tires and from the fronts.. and the difference is the total toe
the toe plates would be faster at measuring toe.. but not as accurate
They want you to buy the scribe.. but any utility knife... nail.. or somthing else that you can hold steady will work... or look at the picture and make your own
[Modified by Crazydave, 7:53 AM 2/14/2002]
Old Feb 15, 2002 | 02:05 PM
dn's Avatar
dn
Default Re: Longacre Toe In Tools (Crazydave)
YES BUY THE BAR....... or make your own. now that i have one, i would have prefered to make my own.
Old Feb 15, 2002 | 04:16 PM
siisgood00's Avatar
New User
Default Re: Longacre Toe In Tools (dn)
How much more accurate is the bar vs. the plates? The plates seem pretty easy but the bar seems to take a lot more effort.
Old Feb 18, 2002 | 03:40 PM
siisgood00's Avatar
New User
ttt
Old Feb 18, 2002 | 06:56 PM
Crazydave's Avatar
The bar is probably more accurate since you don't have to deal with tire imperfections...
but the plates are easier and faster
sure you could make one... take a good look at the picture and head to home depot / lowes
Gustav129
Aug 6, 2012 06:13 AM
00_EM1_Si
Oct 8, 2010 09:24 AM
Tyson
Suspension & Brakes
Mar 29, 2007 12:36 PM
lowRIDAH
12
Jul 26, 2004 03:16 PM
RacerMike
May 29, 2002 12:00 PM
