Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
LCA ???
Old Jun 28, 2009 | 08:06 PM
DIABOLIC8's Avatar
Default LCA ???
I'm doing auto-x and was wondering how different blox, skunk2, form & function, omni, and funtion7 lca are from each other. I was looking at skunk 2 lca but saw that the blox lca's are about $90 cheaper. Is there that much of a difference between the 2, has any1 tried either one??? Thanks for any input.
Old Jun 28, 2009 | 08:15 PM
Stinkycheezmonky's Avatar
Suspetise...
Default Re: LCA ???
Other than minute weight savings, you gain nothing from using an aftermarket LCA (unless your stock LCA doesn't have a provision for swaybar endlinks). Keep things simple and spend the money on something else more important.
Edit: Also, there might be classing issues for autoxing. Another thing to keep in mind.
Old Jun 29, 2009 | 04:07 AM
DIABOLIC8's Avatar
Default Re: LCA ???
Oh ok, i have a 96 ek civic so i'm not sure if they do. Well anyway thanks for the help, do you happen to know if the asr subframe brace would help with the stiffness of the car?
Old Jun 29, 2009 | 05:44 AM
Suspetise...
Default Re: LCA ???
Do you have the stock engine in the car? Do you want to be competitive within your class? The ASR subframe brace alone probably won't do a lot for you.
Old Jun 29, 2009 | 06:47 AM
DIABOLIC8's Avatar
Default Re: LCA ???
No, it has a ls swap. It's not a class type auto x event, it's just a timed event. I just would'nt mind being a bit better around the corners.
Old Jun 29, 2009 | 07:08 AM
jdm civic 2000's Avatar
Default Re: LCA ???
Stay away from LCA's with generic black rubber bushings (blox,omni,generics), they are junk and will deform and break away from the sleeve,within 6 months. Some OK LCA's ive seen thus far that haven't used crap generic bushings are PIC,F7 and the skunk2. However you dont need LCA's, they won't better you in the corners. your stock arms, given the bushings are in well kept condition will be just as good with the same placebo results. save that money and put it into time spent driving.
Joe
Jon777
Suspension & Brakes
57
Jun 26, 2011 06:39 PM
xiLLtegRax
Apr 30, 2006 08:57 AM
The Muffin Man
15
Dec 15, 2003 01:29 AM
PinchE NegRo
12
Jul 24, 2002 09:03 AM
hB eVo
46
Feb 21, 2002 08:45 AM
