Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
KYB shocks?
Old Sep 23, 2002 | 02:50 PM
FitCRX's Avatar
Default KYB shocks?
CRX with H&R race springs. I have been riding with stock shocks for almost a year, I have replaced the shocks(with stock) once or twice, but it seems that I bust them in less than a month(of cource). but its time to finnally put something nice under there.
KYB AGX for $360
KYB GR2 for $220
are the AGX's worth the money? its a street car.
should I go with something else? tokico's? Send me on the right path!!!!
Old Sep 23, 2002 | 02:57 PM
carl_aka_carlos's Avatar
Default Re: KYB shocks? (FitCRX)
what shock you should go with depends on what you want. If you want the ability to adjust the firmness of your ride, the AGX's are great, and cheap too. I'm pretty sure the GR2s are more of a OEM replacement...not necessarily for applications where you're running a stiffer spring than stock. Me, I have the Tokico HP shocks, and they're great for the street, but a tad too soft for autoX, that's why I have koni single-adjusables with GC's and eibach 450f/500r springs.
Old Sep 23, 2002 | 08:05 PM
Trickturn's Avatar
Default Re: KYB shocks? (carl_aka_carlos)
http://www.coximport.com
$330 shipped to you KYB AGX. BEST shox out there for spring rates under 400 lb in
Pete
Old Sep 23, 2002 | 10:43 PM
Mojo-Jojo's Avatar
Default Re: KYB shocks? (pest)
I'm loving my AGX's, but I've got the H&R Sports.
I don't think they could handle the Race rates and still be comfy.
You might want to go for the Koni Yellows if your budget can handle it. If not, the AGX's will still be good, but probably a bit less cushy.
Oh, and if I remember correctly, the GR2's are essentially setting 2 on the AGX's. 15% stiffer valving than stock.
[Modified by Mojo-Jojo, 11:44 PM 9/23/2002]
Old Sep 23, 2002 | 11:55 PM
highmilehatch's Avatar
Default Re: KYB shocks? (Mojo-Jojo)
Are you sure about the gr2 being 15% stiffer? Can the gr2 handle the same rates as the agx?
Old Sep 24, 2002 | 07:20 AM
Mojo-Jojo's Avatar
Default Re: KYB shocks? (turboeg)
This is the email I got from someone here on HT, that got it from KYB techs:
Please refer to the AGX adjustment chart below:
The AGX products have the following approximate damping force
values. When adjusted, both rebound and compression damping forces change.
Setting#:
1 - Same as Factory
2 - Same as our GR2 products (10~15% firmer than Factory)
3 - 50% firmer than #2
4 - 30% firmer than #3
With an 8 position adjustable, #1 is approx 5% softer than Factory.
Setting #'s 3,5,& 7 split the differences between #'s 2,4,6,& 8.
bigBOI_92DA9
Aug 31, 2005 06:30 AM
SouLaQuaRiuS
Nov 4, 2003 02:20 PM
FlipboiGSR
Jun 26, 2003 07:30 AM
Cryptopsy
41
Dec 19, 2002 01:24 PM
chiefvtec
Jul 9, 2002 11:39 AM
