Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
How Do I Launch With LSD
Old Apr 21, 2002 | 06:35 PM
TruePlayaz114's Avatar
Default How Do I Launch With LSD
I have a 92 4 dr civic with a b18c. I have pretty much every bolt on you can get except for pulley's which are on the way soon. I have i/h/e cam gears, fuel rail and regulator, MSD ignition with a coil. Mugen clutch with a Excedy flywheel, Apexi V-AFC and a ITC. I've tryed different RPM's to launch at but the lower I do it the slower I go but the higher I launch at the more wheelspin I get. I can shift perfectly and do everything fine but I'm not happy with my launching. Can someone give me some advice or some pointers.
Old Apr 21, 2002 | 07:17 PM
Mike P.'s Avatar
25 Year Member
Default Re: How Do I Launch With LSD (TruePlayaz114)
Sounds like you sorta answered your own question. The lower the launch the more it bogs, and if you go high the wheels will spin. I guess it's time to go to the track and practice until you find the "fine line" to launch from. Drag racing a Honda requires a precise touch.
[Modified by Mike P., 11:17 PM 4/21/2002]
Old Apr 21, 2002 | 07:35 PM
Default Re: How Do I Launch With LSD (Mike P.)
Where do most GSR's launch from?. Or better yet where do most civics with GSR motors launch from?
Old Apr 21, 2002 | 07:41 PM
Mike P.'s Avatar
25 Year Member
Your results may or may not be the same as someone elses. Best thing to do is to go to the track, using the trial-and-error technique to see what works the best for your combination. My experience is that it's better to have a little wheelspin on the launch with these low torque engines.
Old Apr 21, 2002 | 08:11 PM
Does anyone else have any more advice? I need all the help i can get
Old Apr 21, 2002 | 08:18 PM
MaddMatt's Avatar
This may be as good as it'll get around here. Not many people drag race in this forum. Sounds like you need seat time to figure out what is just right for your car.
Old Apr 22, 2002 | 04:05 AM
Crosser's Avatar
Best bet for trail and error, is start at 2,000 rpm and continue to increase the launch rpm by 500 each run, until you are getting too much wheel spin. Then back it down slightly.
My CRX w/ Quaife launched best at the strip at about 3000 rpm depending on the surface of the track. This can cahnge though from car to car, track to track, and even event to event at the same track. The surface is different based on how they treated it. You just have to be able to adapt.
Best tool is looking at your 60' times.
Old Apr 22, 2002 | 01:47 PM
LXguy's Avatar
Default Re: How Do I Launch With LSD (Crosser)
Hey:
What kind of tires are you using? What PSI? Are you doing a burnout?
Steve
Old Apr 22, 2002 | 02:11 PM
ZUL8R's Avatar
Default Re: How Do I Launch With LSD (LXguy)
start your car with no axles
Old Apr 22, 2002 | 07:23 PM
Default Re: How Do I Launch With LSD (shane Z)
Right now I have 17inch Konig monsoon rims with 205/40/ZR17 Falken tires. I'm about to buy the Rota Slipstream's or the Circuit 8's with Toyo Tires. I'm not sure exactly which tires but they're something like T1s or something like that
Built2.0Lude
Apr 8, 2004 12:45 PM
h huff
Jan 20, 2003 01:45 PM
tygsr
May 23, 2002 11:37 AM
TruePlayaz114
Apr 21, 2002 06:26 PM
4G-CIVIC
Sep 22, 2001 08:47 AM
