Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
help!! with cam lock...
Old Feb 22, 2004 | 05:27 PM
spock_rocker's Avatar
memoryFAB.com representative
Default help!! with cam lock...
i feel like such a noob and im sure i will want to kill myself after i
figure this out.
ok, i took the harnesses out of the camlock. all 3 go back in just fine execpt the right side slot. it appears to be a bolt or something in the way. now obviously it releases but i cant get it back in.. it doesnt snap in the the others....
*slaps forehead*
thanxx in advance!!
Old Feb 22, 2004 | 06:02 PM
Knestis's Avatar
Default Re: help!! with cam lock... (spock_rocker)
Camlock buckles typically have five slots that belt tang ends go into - four that are controlled by the **** (that open and close) and one that has a machine screw through it. You can mount the buckle on a lap belt or the crotch strap, for example, or on the right or left lap, orienting the buckle however you want but one tang has to be bolted into the buckle.
It's not clear from your description if you have a crotch strap installed. If you don't - and are using only four of the slots - you may be trying to put a tang end in the one with the screw. Look on the back side of the buckle for its head.
K
Old Feb 22, 2004 | 06:39 PM
Default Re: help!! with cam lock... (Knestis)
no i dont have a crotch strap... its only a 4 pt harness..
ToFu-DeLiVeRy
Sep 21, 2004 05:47 PM
Poop111444
Aug 2, 2003 11:45 PM
216.226.142.95:27016
Jun 28, 2003 05:55 PM
Luserkid
Mar 29, 2003 08:03 PM
