Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Getting rid of that sunroof...
Old 06-18-2010, 02:25 AM
maxogsr's Avatar
Default Getting rid of that sunroof...
It's been a while that I'm thinking about getting rid of the sunroof... I'm looking for differents options, cheap and simple if possible and also clean that willl last... I did a search but most tread are old and pics have been taking away
Old 06-18-2010, 03:47 AM
Suspetise...
Stinkycheezmonky's Avatar
Default Re: Getting rid of that sunroof...
Cheap, simple, AND clean? Sorry bud, doesn't quite work like that, unless you're willing to put in the elbow grease to fab up something yourself. There are some CF plugs floating around, but they are not cheap. Other than that, I'm not sure there are any readily-available premade ones. There are some decent write-ups about how to make your own though.
There is also the option of replacing most of the roof. This tends to be done for cage building, but would result in pretty significant weight loss if you have the reinforced sunroof skeleton currently.
Unfortunately, some of the older (and even some of the more recent!) threads covering this no longer have pics hosted. This thread has some useful links in it: https://honda-tech.com/forums/showthread.php?t=2567725&highlight=sunroof
And Powerneedy's build shows the full-roof replacement: https://honda-tech.com/forums/showth...hlight=sunroof
Old 06-19-2010, 09:40 AM
ej1 rep's Avatar
I would love to have a sunroof! keep it!
Old 06-19-2010, 10:46 AM
powerneedy's Avatar
There is no Cheap, simple, AND clean look... Cheap would be a sheet of metal your choose riveted or welded in...
Clean would be a carbon roof like in the picture. Clean and pretty easy to do if oyu can get past the fact of cutting some metal
Old 06-19-2010, 11:21 AM
GRM92Civic's Avatar
I'm looking for the same thing, but I have to carefully do it the right way.
I'm converting my Si to a VX for Solo2 FSP class. Taking all that sunroof weight out at the top of the car will actually make a big difference since I have limited power.
I'm actually looking for a donar VX to take the headliner supports and skin from. It won't be cheap but it's cheaper than finding a clean VX hatch and swapping my Si drive train over.
Old 06-19-2010, 03:23 PM
maxogsr's Avatar
I said cheap, but I din't mean that cheap... I've been looking for quite a while at the lighterfaster carbon plug, but I would prefer adhesive insted of welding... Most bodyshop use adhesive but it would involve an other design... Anyone have good pictures of what it look like from inside when all the sunroof is out of the car... that would help me...
Old 06-19-2010, 03:28 PM
maxogsr's Avatar
If your willing to pay the shipping charge I'll send it to you! It has nothing to do in a racecar...
Old 06-19-2010, 03:48 PM
powerneedy's Avatar
I dont have any pics it just looks like metal will a couple cross if you would call them braces for the sun roof to bolt to. nothing to it. if you cut out the whole roof its put on with adhesive
Old 06-21-2010, 06:04 AM
mc-integra111's Avatar
If it's a race car than remove the sunroof mechanism, cut a piece of sheet metal to cover the hole (make sure to check your class rules to see if the plug material must be the same as the existing roof), and rivet it to the roof (use a sealer to make sure it doesn't leak).
Old 06-22-2010, 06:21 PM
raffaelli's Avatar
My ITA car has a piece of sheet metal riveted to the roof.
Old 06-26-2010, 06:15 PM
niteridaV2's Avatar
Get a carbon roof cap? with some kevlar reinforcement near the opening. I have made some that way in the past
Old 06-26-2010, 06:30 PM
BLK2DOOR's Avatar
Wow I have one of those slide back sun roofs I have to cover i think I might just rivet a big piece of sheet metal in.
Old 06-27-2010, 12:35 AM
uniseriate's Avatar
There is always reskinning the roof (as documented here) if you are feeling adventurous.
Old 07-03-2010, 07:21 PM
a97b18b's Avatar
are you not aloud to have a sunroof on the track or are you guys just getting rid of it?
Old 07-05-2010, 11:24 AM
What is this crap?
falcongsr's Avatar
lots of weight up high is bad. i would appreciate the extra headroom to fit a helmet.
Old 07-05-2010, 11:37 AM
The Destroyer's Avatar
A friend of mine has this in place of his.
http://www.corsportusa.com/store/cat...oducts_id=6968
Old 07-05-2010, 11:58 AM
liam821's Avatar
Yeahh $370? What a rip-off. I might go for that if it was under $50. Id rather do the home depot $10 in parts method.
Old 07-05-2010, 12:27 PM
He's the kind of person that buys volks on a whim so im sure he didnt even consider the price.
No ones twisting your arm to buy it either, it was posted for the idea, and the option.
Old 07-05-2010, 06:52 PM
raffaelli's Avatar
If you are racing in SCCA Club Racing, sun roof has to be pluged.
Old 07-05-2010, 07:04 PM
The answer to that (like just about everything) is it depends. Pay close attention to the class rules. Improved Touring requires glass sunroofs to be removed, others may be run in the closed position. Showroom Stock allows even glass sunroofs to remain in the closed position.
Old 07-05-2010, 10:53 PM
Colin's Avatar
Be careful with the carbon roof caps, you may not end up with the "clean" look you want. I opted to go this way. It was easier than welding in an RS roof (my preferred method) and not much more expensive than a lighter faster plug (but looks better, IMO), but it's far from a nice quality piece. I'm sure there are high quality ones out there, but if you're **** about quality be sure to see the piece in person before purchasing, photos can hide tons of flaws. But functionally it's fine so far, I just hope it's not too thin and thus possibly not very long lasting.
Old 07-06-2010, 01:03 AM
Reyes's Avatar
i have mild experience with carbon and can vacuum bag at my house..i'm debating on making a carbon plug for my civic too.
Old 07-06-2010, 04:33 AM
raffaelli's Avatar
If you plan on re-creating the roof or plugging the hole with carbon fiber, check the rules of the class you plan of being it...some only allow metal.
erickitho
10-07-2011 02:30 PM
dirtyharryhatch
04-08-2008 12:10 PM
ibevila
01-16-2008 05:03 PM
RBNightMare
07-06-2007 11:05 AM
Quick Reply: Getting rid of that sunroof...
