Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
fuel problems need help please
Old Jan 29, 2008 | 05:23 PM
mystic-s's Avatar
Default fuel problems need help please
k folks im using the standard ef9 fuel tank with a uprated pump now heres the problem if the tank goes under 1/4 and if i take tight corners at speed the engine dies for a few seconds how would i go about stopping this like could i put something in the tank or even make something
your help would be great
Old Jan 30, 2008 | 03:10 PM
mystic-s's Avatar
Default Re: fuel problems need help please (mystic-s)
bump
Old Jan 30, 2008 | 03:15 PM
chad's Avatar
Moderator
you shouldn't be going that fast on the street!
Old Jan 30, 2008 | 04:09 PM
Stinkycheezmonky's Avatar
Suspetise...
Default Re: fuel problems need help please (chad)
Yeah. The solution: slow the hell down.
Edit: You didn't SAY this was on the street, but sure sound like it... So how about that detail?
Modified by Stinkycheezmonky at 5:22 PM 1/30/2008
Old Jan 30, 2008 | 07:23 PM
nfn15037's Avatar
Default Re: fuel problems need help please (Stinkycheezmonky)
Can anyone answer a question in this forum without jumping on someone because they might seem like they kinda maybe might be driving fast on the street? For christ sakes people, lay the eff off. Seriously, I hate street jackassery, but time after time after time I see the same crusty old posters spewing the same bile. And without so much as a MENTION of 'canyons', VTEC, or exit ramps.
To the OP whom I HOPE isn't doing anything dangerous on the street with his car:
Maybe when you installed your pump, you didn't get it far enough down into the tank or the pump got twisted up in there during install? I would check that first and go from there. Perhaps your EF has no baffles in the tank? Many Hondas don't.
Old Jan 30, 2008 | 07:29 PM
Suspetise...
Default Re: fuel problems need help please (nfn15037)
I'll admit I've become testy lately. The asshat variety of noob has been running rampant the past couple weeks, and it's just really f'ing old. Hence my possible correction
I've seen another problem where the plastic pick-up tube thingy gets cracked, which creates the exactly described symptom. However, that's an Integra pump in a Civic.
Old Jan 30, 2008 | 07:41 PM
Another Drew's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nfn15037 &raquo;</TD></TR><TR><TD CLASS="quote">but time after time after time I see the same crusty old posters spewing the same bile. </TD></TR></TABLE>
I'm thankful to the crusty old poster you're talking about. I have the same sentiment as they do, and they save me the time it takes to reply to all those noob/streetracer posts.
Old Jan 30, 2008 | 08:15 PM
essex's Avatar
Default Re: fuel problems need help please (Another Drew)
It's definitely an EF problem.Obviously no EF people in this topic lol
https://honda-tech.com/zerothread?id=1339791
Old Jan 31, 2008 | 08:48 AM
FlyZlow's Avatar
Default Re: fuel problems need help please (essex)
Yeah, my CRX with the stock tank and pump did that constantly on the track. I had to keep it over 1/4 tank full if I didn't want to fuel cut in the tighter corners.
Old Jan 31, 2008 | 03:14 PM
sgallagher's Avatar
Default Re: fuel problems need help please (FlyZlow)
Is it possible/legal to add foam to the tank to help keep the fuel from sloshing? Just an idea.
Old Jan 31, 2008 | 04:23 PM
Grumpy's Avatar
New User
Default Re: fuel problems need help please (sgallagher)
Foam does NOT prevent sloshing. It inhibits the flame front when on fire. NASCAR fuel cells are full of foam, does it look like its slows down anything when they refill???
Old Jan 31, 2008 | 04:30 PM
Lo-Buck EF's Avatar
had u searched this topic, you would have found many topics on this EXACT issue. the fix-buy my good ef tank. doesnt fuel starve at the fuel line at autocrosses. comes with entire car.
Old Jan 31, 2008 | 04:48 PM
TunerN00b's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by essex &raquo;</TD></TR><TR><TD CLASS="quote">It's definitely an EF problem.Obviously no EF people in this topic lol
https://honda-tech.com/zerothread?id=1339791</TD></TR></TABLE>
Not just an EF problem. My DC2 does it under 1/4 tank on long right sweepers during autocross.
My solution is to always have a 1/2 tank of gas.
Old Feb 2, 2008 | 06:34 PM
ejprimo's Avatar
Default Re: fuel problems need help please (TunerN00b)
i can never have less than 1/3 of a tank because of the same problem in fast corners.
Old Feb 5, 2008 | 04:47 AM
mystic-s's Avatar
k well sorry for the misleading start ment to say its a track car and im trying to cut how much weight i have in it so fuels the next step but under 1/4 it cuts on tight bends
Old Feb 5, 2008 | 03:10 PM
Crx Jimmy's Avatar
Default Re: (mystic-s)
Unless you cut the tank to install baffles, Just add more gas, my crx does it as well, its a ef thing.
kayley94
Jun 17, 2019 07:25 PM
Black R
Jun 26, 2004 11:49 PM
TeamFlewellen
Apr 13, 2004 04:00 PM
CRneXt
Apr 15, 2003 08:44 PM
Holden
13
Jul 17, 2002 11:04 PM
